ⓘ Refer to Dante V3 Firmware Update Instructions for instructions on how to update the Dante cards.
ⓘ This version of firmware is for Dante V3 option cards only. These can be identified by the presence of “V3” on the front panel. The following V3 cards are available:
| Dante Card | Part Code | Mixer |
| Dante64 V3 | M-DL-DANT64 | dLive, Avantis |
| Dante128 V3 | M-DL-DANT128 | dLive, Avantis |
| SQ Dante32 V3 | M-SQ-DANT32 | SQ, AHM |
| SQ Dante64 V3 | M-SQ-DANT64 | SQ, AHM |
ⓘ The current version of firmware supports the following:
- Max number of DT168/DT164-W expanders on a Dante network: 32
- Max number of DT168/DT164-W expanders within a Dante Domain Manager network: 16
Latest Release
V1.0.4 - February 2026
Maintenance release.
Improvements
Max number of DT168/DT164-W expanders on a Dante network increased to 32
Max number of DT168/DT164-W expanders within a Dante Domain Manager network increased to 16
Fixes
ID36 - 'Sync to Ext' could cause other devices on the network to become Muted
DT preamp controls could be missing, unavailable or work incorrectly in the following circumstances:
ID73 - Adding DHCP to an active Dante network.
ID75 - Hot-plugging a DT device in large networks with several DT devices.
ID77 - 3 or more A&H Dante cards sharing DT expanders.
Known Issues
ID1326 - Adjusting preamp settings after a DT device is disconnected can result in mismatched settings when reconnecting the device.
ID25 - Unplugging card while in DDM can cause preamp control to disappear and channel to revert to trim control only.
ID9881 - Rapid scenes recalls including changes to multiple DT devices can prevent Preamp gains being recalled correctly.
Previous Releases
V1.0.3 - March 2025
Fixes
ID32 - Clock Leader cards set to Redundant mode could occasionally present latency issues and mute Dante audio after a period of time.
ID29 - In certain circumstances with specific third-party hardware, cards would crash when attempting to acquire a DHCP address.
V1.0.2 - October 2023
Feature release.
New features
Support of SMPTE-ST2110-30 streams in Dante Domain Manager.
Fixes
ID21 - Improved multicast reliability on Secondary Link.
ID24 - Support for AES67 & SMTPE-2110-30 when used as part of a DDM network.
ID26 - The Control Network port and Control Network bridge would erroneously block Shure multicast data necessary for Shure RF integration in dLive and Avantis.
V1.0.0 - Feb 2023
This was the first release of V3 Dante firmware.
