Aim: To reset mixer information and passwords.
Tools: T10. Module extraction tool Requirements:
- Removal of iLive CPU module. Refer to iLive service document 08
- Removal of iDR10 CPU module. Refer to iLive service document 08
Reset procedure
- Power OFF.
- Remove CPU module. Refer to iLive service document 2.08
- Locate jumper bank JP4. During normal operation, all jumpers should be OFF
- Put appropriate jumper link to ON position. This picture shows J5 ON to reset mixer settings.
- Replace CPU module.
- Power ON and allow unit to fully boot.
- Power OFF.
- Replace jumper link to OFF position.
- Power ON and allow the unit to fully boot.
- The desired reset is now complete.
The following lists jumper function and memory locations.
Jumper links
J5 Resets mixer settings
- Processing - current settings [iDR10 CPU]
- Strip assignments [i-Live CPU]
J6 Clears all scenes [Both i-Live and iDR10 CPU]
J7 Clears configuration sector
- Input setup – mono and stereo channel settings [MixRack CPU]
- Mix configuration [MixRack CPU]
- Buss configuration [MixRack CPU]
- Reset user profiles
- User names
- User passwords
- User permissions
- User default power-up scene
- IP address [Both i-Live and MixRack CPU]
J8 Reset user profiles. Up to→ V1.32 J8 on the SURFACE CPU
V1.40 → J8 on the MIXRACK CPU
- User names
- User passwords
- User permissions
Memory location
Scene – Both MixRack and iLive. MixRack Settings stored in MixRack. Strip assignments, local mic pre and local digital source select are stored in iLive. Cleared by J6.
Show – Stored on SBC on compact flash or USB.
FX – Stored as Libraries on SBC compact flash or USB. Current settings are saved in the scene (see above).
Permissions –iLive – Flash (Config Sector) Cleared by J8 OR J7 see notes above.
Processing – (Current Settings) Stored in battery-backed SRAM – MixRack CPU PCB. Cleared by J5.
User profiles – iLive – Flash (Config Sector) Cleared by J8 OR J7 see notes above..
IP – Both MixRack and iLive – Flash (Config Sector) Cleared by J7. Also on SBC compact flash.
Event log – Both MixRack and iLive in BB SRAM.
Preferences. Most are stored locally to the host they affect.
Date/time. MixRack and iLive, Clock Chip on CPU PCB. SBC compact flash. All set using SBC.
Mix Configuration – MixRack – Flash cleared by J7
Bus Configuration - MixRack – Flash cleared by J7
Strip assignment – iLive BBSRAM cleared by J5
