Surface Method
If you have an iLive surface connected to your iDR mixrack then follow these instructions:
- Insert a USB key into a spare USB socket on the surface
- Press the Utility button
- Press the Diagnostics button (on-screen)
- Press the Event Logs button (on-screen)
- Press Store all logs to USB (on-screen)
The logs are now stored on your USB key in the directory
Editor Method
If you do not have a surface connect to your iDR mixrack then connect a computer running iLive Editor software and then follow these instructions:
- Select the Help menu
- Click Status
- Click Event Logs
- Click Save Logs
You can now select where you want to store the logs.
