Power
IEC connectionMain power connection with power on/off switch. Use the ‘P-Clip’ to secure mains power cable where required. |
Local Inputs
Combi InputsBalanced XLR (1-Ground, 2-Hot/Positive, 3-Cold/Negative) Or ¼” TRS Jack (Tip-Hot/Positive, Ring-Cold/Negative, Sleeve-Ground) Recallable preamp with +60dB gain, fixed -20dB pad on TRS input, phantom power supplied to XLR connection only. |
TalkbackBalanced XLR (1-Ground, 2-Hot/Positive, 3-Cold/Negative) Recallable preamp with +60dB gain and phantom power. Patchable to input processing channels. |
Stereo Line Inputs2x ¼” TRS Jack (Tip-Hot/Positive, Ring-Cold/Negative, Sleeve-Ground) Normalled (L/M, R), connect mono signals to left socket only. Digital trim available in processing channel. |
Local Outputs
XLR Line OutputsBalanced XLR (1-Ground, 2-Hot/Positive, 3-Cold/Negative) Nominal +4dBu output (when output meter displays 0dB) |
TRS Line OutputsBalanced ¼” TRS Jack (Tip-Hot/Positive, Ring-Cold/Negative, Sleeve-Ground) Nominal +4dBu output (when output meter displays 0dB) |
AES Digital OutputStereo digital output on XLR for use with 110-ohm balanced cables. |
HeadphoneStereo ¼” TRS Jack (Tip-Left, Ring-Right, Sleeve-Ground). Recallable digital trim control. |
SLink
SLink multichannel audio networking portetherCON RJ45 port for expanding the Qu using the Allen & Heath Everything I/O range of expanders. Mode automatically switches between dSnake/ME, DX and gigaACE/GX protocols. |
| Protocol | Sample Rate | Max Input Sockets | Max Output Sockets |
| DX | 96kHz | 32 | 32 |
ⓘ SLink does not support multiple protocols on a single connection.
ⓘ Connecting expanders increases the number of available input and output sockets in the system, it does not change the number of input or mix processing channels available.
Dante (Qu-5D, Qu-6D, Qu-7D only)
Dante multichannel audio networking portetherCON RJ45 port for connecting the Qu to a Dante network, or directly to other Dante enabled equipment. Includes preamp control when used with Allen & Heath DT expanders. 16x16 channels of audio at 48kHz or 96kHz. |
USB and SD Card
USB-A(Qu as host, for audio and data storage and recall) |
USB-C(Qu as client, for audio and MIDI). |
SDHCFull size SD card slot.
Network
RJ45 Network portThis is used to connect the Qu to a wireless router, access point, local area network or directly to a device, allowing the Qu to transmit and receive control data. For use with Allen & Heath Qu apps, and for MIDI over TCP/IP. |
Footswitch
Mono (TS) or Dual (TRS) ¼” JackCan be calibrated for use with momentary or latching switches. |
