Options are available to
- Convert RIAA stage (phono input) to line level.
- Disable Filter On switch
- Change the USB Audio input feed from the RCA sockets on the rear panel (default) to the internal left/right mix buss
Please see the User Guide for more information.
CAUTION: The service instructions are for use by qualified personnel only.
To reduce the risk of electric shock do not perform any servicing other than that described in the operating instructions unless you are qualified to do so. Refer all servicing to qualified service personnel.
Your dealer or local distributor will be able to assist if you need further help
