Q:
... when I attempt to map the Input Routing in TRAKTOR PRO to my Xone:4D, I only see 'MASTER IN' as the options in the dropdown.
This is the same in the output routing (I only see 'MASTER OUT').
What should my settings be here?
A:
In Mac OSX, Traktor Pro will recognise all Xone:4D soundcard INPUTS and OUTPUTS as MASTER IN (1-10), and MASTER OUT (1-10) connections.
These relate, sequentially, to each of the XONE:4D soundcard inputs or soundcard outputs, so that:
1: MASTER IN = XONE:4D INPUT SC1/2_1 = XONE:4D INPUT 1 L
2: MASTER IN = XONE:4D INPUT SC1/2_2 = XONE:4D INPUT 1 R
3: MASTER IN = XONE:4D INPUT SC3-4_3 = XONE:4D INPUT 2 L
4: MASTER IN = XONE:4D INPUT SC3-4_4 = XONE:4D INPUT 2 R
5: MASTER IN = XONE:4D INPUT SC5-6_5 = XONE:4D INPUT 3 L
6: MASTER IN = XONE:4D INPUT SC5-6_6 = XONE:4D INPUT 3 R
7: MASTER IN = XONE:4D INPUT SC7-8_7 = XONE:4D INPUT 4 L
8: MASTER IN = XONE:4D INPUT SC7-8_8 = XONE:4D INPUT 4 R
and
1: MASTER OUT = XONE:4D OUTPUT SC1/2_1 = XONE:4D SC 1/2 CH1 L
2: MASTER OUT = XONE:4D OUTPUT SC1/2_2 = XONE:4D SC 1/2 CH1 R
3: MASTER OUT = XONE:4D OUTPUT SC3-4_3 = XONE:4D SC 3-4 CH2 L
4: MASTER OUT = XONE:4D OUTPUT SC3-4_4 = XONE:4D SC 3-4 CH2 R
5: MASTER OUT = XONE:4D OUTPUT SC5-6_5 = XONE:4D SC 5-6 CH3 L
6: MASTER OUT = XONE:4D OUTPUT SC5-6_6 = XONE:4D SC 5-6 CH3 R
7: MASTER OUT = XONE:4D OUTPUT SC7-8_7 = XONE:4D SC 5-6 CH3 L
8: MASTER OUT = XONE:4D OUTPUT SC7-8_8 = XONE:4D SC 5-6 CH3 R
The Xone:4D digital (SPDIF/OPTICAL) inputs/outputs listed in the Traktor Pro Input Routing / Output Routing preferences as:
9:MASTER IN / 10:MASTER IN
and
9:MASTER OUT / 10:MASTER OUT
The Xone:4D Soundcard Inputs or Outputs can be assigned any of Traktor's Decks (A, B, C, D) as required.
Note, if you are not routing an external audio, or encoded vinyl, signal source into Traktor Pro, we recommend leaving Input Routing options set to ‘not connected’.
