Q:
... I am trying to get some information about the Xone:2D. There doesn't seem to be any online that helps me out.
A:
Have you looked here?
You can download the full User Guide for full details, including technical specs, via this link.
Q:
I'm slightly confused with what the Xone:2D actually is.
A:
The Xone:2D is a Professional Digital Music Interface featuring a combination 9, stereo channel (on RCA phono/line and XLR MIC connectors), 96kHz/24-bit USB2.0 soundcard and MIDI controller. For best results, a Xone:2D can be combined with any multi-channel analogue DJ mixer, but it is also possible to use the interface as a 'stand-alone' DAW application mixer.
Q:
There seems to be 2 different Xone:2Ds shown by suppliers; one has a crossfader and the other one doesn't.
Is the one without an x-fader just an older image that’s floating around? It would be a bit of a let-down if I received the one without the x-fader.
A:
Pictures of the Xone:2D without the cross-fader, XLR MIC and headphone connectors on the top panel are from the early concept units.
Q:
Is it possible to use one unit to control 2 virtual decks in Traktor?
A:
Absolutely! In fact, if you're competent with the application, clever with your MIDI maps, and dexterous with your hands - you can control 4 virtual decks in Traktor or 8+ tracks in Ableton Live.
Xone:2D will also work well with many other DAW software applications.
Q:
Can you switch controls between Traktor decks A & B. i.e.: use the jog wheel to nudge a track playing into time like you would on a turntable/CD deck?
A:
Yes - although exactly how the MIDI controls work with these parameter functions is down to how the software application's MIDI 'mapping' is configured; that is something that is open to bespoke customization depending on how you want to use the 2D interface with the software.
Q:
I have heard from friends who use two Xone:1D's, that you must use 2 separate USB slots for each unit.
Is that also the case if I had a xone1 and zone2? or can they run from the one USB slot with an adapter?
This is something that I’m looking into doing in the future.
A:
You only need one USB port for each Xone:D series unit.
If you're thinking of adding a Xone:1D (which is a common 2D setup addition), you need a second USB slot on your computer for this device.
For certain types of laptops, however, you may also need to use a powered USB hub (to act as the PSU for the additional Xone:1D).
The two Xone devices can then be connected via a single 5pin DIN MIDI cable for integration with your DAW software.
Q:
I really hope that this unit does what I think it does because I'm sick of lugging 20 kilos of vinyl around with me and this could be a great solution.
A:
Then the Xone:2D is an ideal solution. If you're playing in clubs with an analogue mixer & hardware already installed, you can pack a complete 2D setup (including laptop, all leads & a MIC) tidily into one DJ bag and a CD-holder sized flight case!
