The Xone:V6 Hybrid Linear PSU (MPS6) produced after May 2004 can power both early versions of the Xone:V6 (just 2 valve channels) and later models that had valves fitted to all input channels as standard (after serial number XV6 080001 X). Or the early 2 valve option models fitted with the all valve option kit.
Caution: DO NOT try to power an 'all valve' version with a PSU produced before May 2004.
If you are in any doubt, or to arrange for a service/repair if required please contact Union Audio
DISCLAIMER
- All work must be carried out by a competent engineer.
- AC supply and DC supply can both be LETHAL. Switch mode PSUs can operate at around 400VDC internally.
- Allen & Heath are not responsible for damage or harm caused to persons or equipment.
- The use of an alternative PSU may result in hum, buzz or other noise due to the PSU or DC cable grounding being optimised for another mixer.
Note: The Xone:S6 PSU (MPS7) will not power a Xone:V6
