ⓘ Refer to Qu Dante Firmware Update Instructions for instructions on how to update the Dante module in a Qu mixer.
ⓘ This firmware is for Qu mixers with built-in Dante, including the Qu-5D, Qu-6D and Qu-7D.
ⓘ The current version of firmware supports the following:
- Max number of DT168/DT164-W expanders on a Dante network: 32
- Max number of DT168/DT164-W expanders within a Dante Domain Manager network: 16
Latest Release
V1.1.0 - October 2026
Feature release.
Features
Support for 32x32 Dante Upgrade Add-On
Known Issues
ID1326 - Adjusting preamp settings after a DT device is disconnected can result in mismatched settings when reconnecting the device.
ID25 - Unplugging card while in DDM can cause preamp control to disappear and channel to revert to trim control only.
ID1434 - Dante traffic can briefly contact the Qu during startup for a couple seconds, potentially providing a DHCP address to the Qu mixer from a DHCP server on the Dante network.
Previous Releases
V1.0.2 - February 2026
Maintenance release.
Max number of DT168/DT164-W expanders on a Dante network increased to 32
Max number of DT168/DT164-W expanders within a Dante Domain Manager network increased to 16
ID36 - 'Sync to Ext' could cause other devices on the network to become Muted
ID1411 - Connecting Network and Dante ports to the same switch (separate VLANs) could cause audio interruptions
ID1408 - Rebooting Dante from Dante Controller could cause Network bridge to get set incorrectly
ID1388 - Network and Dante traffic could mix for a few seconds during boot
DT preamp controls could be missing, unavailable or work incorrectly in the following circumstances:
ID73 - Adding DHCP to an active Dante network.
ID75 - Hot-plugging a DT device in large networks with several DT devices.
ID77 - 3 or more A&H Dante cards sharing DT expanders.
V1.0.1 - May 2025
This was the first release of Qu Dante firmware, installed at production.
