Scene memories
Scene memories store the following parameters and settings:
Input channels
- Preamp Gain, Pad, +48V
- Digital Trim, Polarity
- Stereo Image
- HPF and LPF Filters
- Insert In/Out and operating level
- PEQ
- Gate and Compressor
- Level (channel fader)
- Mute
- Pan
- Routing assignments, sends and Pan
- Delay
- Direct Out level
- DCA / Mute Group assignments
- Name & Colour
Mix channels
- Ext Input Gain, Pad, +48V
- PEQ
- GEQ
- Compressor
- Mute
- Pan
- Delay
- Name & Colour
- Source point
FX Sends, FX Returns
- Level
- Mute
- Name & Colour
FX
- FX parameters for each unit
- FX processing (PEQ and Dynamics)
DCA
- Assignments
- Level
- Mute
- Name & Colour
Others
- AMM Settings
- IP Controllers settings
- Source Select settings
- Dyn8 routing and parameters
- Softkeys settings
- GPIO settings
- Patchbay – Input source, Inserts, Outputs
- Virtual SoundCheck settings
- I/O Port – Option card settings
- Output Polarity
- Digital Out Sample Rate
- Source Selectors
- Ganging
- ME Stereo configuration for Monitor outs
- Global Direct Out source
- AMM settings
- Global Tap Tempo
- Global Key
- RTA Control
- PAFL strips Name & Colour
- Strip Assigns for each bank
- Surface illumination
- Soft Rotary controls
- Talkback HPF
- Talkback Groups
Mute Groups
- Assignments
- Mute
MIDI Strips
- MIDI messages
- Name & Colour
Show memories
Show memories store the following settings:
Current settings
- All settings listed above, stored at the time the Show was last saved
Scenes
- All Scenes (1-500) including names and descriptions
- Scene Recall Filters
- Global Scene Safes
- Role Profile and Role Safes
- Cue Lists and Recall IDs
- Current cue list
- Scene options (Editing Confirmation, Auto Store, Auto Increment, Track Embedded, Go on Touch)
Libraries
- All User Libraries
Actions
- All Actions
MixRack Setup
- Mixer Configuration
- Input Stereo Configuration
- Audio Clock source
- BNC Wordclock out option
- Talkback assignments, source assignment, HPF and Dim option
- SigGen assignments and settings
Surface Setup
- AES out sample rate options
- AES input SRC bypass
- Strip Assign ‘Sync Selected Layer with Surface’ option
- Custom Rotary functions
- Layer Link
- Surface preferences (Display parameter on LCD, No Sends on Faders)
PAFL
- PAFL preferences (Additive mode, IEM Mix to Headphones, Mix Follows PAFL, Sel Follows PAFL, AFL option)
- PAFL Delay and Trim
- Mains to PAFL levels
- External Input Talk to PAFL switch and Trim
Others
- PEQ / Comp order
- Custom meters
- Quick Names
- MIDI Channel number
- Input PEQ 20-20k option
- Mix PEQ 20-20k option
- Fill PEQ graphs option
- I/O Screen options
- RTA ‘Show Peak Band’ option
- ‘Enable Preamp on Surface’ option
Settings not stored in Shows
The following settings are not stored in Show memories. These settings are local to the MixRack or Surface.
- Network settings
- Event logs
- VGA Screen out mode
- User Profiles
