The following readings are when the master meter is reading 0dB. With the level control fully clockwise (10). Set here the balanced XLR output will be running at +4dBu. The number 7 on the dial is marked black, this is to indicate where unity is (0dB) in reflection to the mix bus VU meter. This is the same for both Master 1 & Master 2 outputs. | |
The following readings are when the master meter is reading 0dB. With the level control fully clockwise (10). Set here the balanced XLR output will be running at +4dBu. Unity (0dBu) is around 3 o’clock (8 on the dial). Mix 2 runs at +4dB around 3 o’clock (8 on the dial). and +8dBu at max (10 on the dial). | |
The following readings are when the master meter is reading 0dB. With the level control fully clockwise (10). Set here the balanced XLR output will be running at +4dBu. Unity (0dBu) is around 3 o’clock (8 on the dial). | |
The following readings are when the master meter is reading 0dB. On 43/43C master level, around 7 the main balanced XLR output will be running at +4dBu. Unity (0dB) is around noon (5 on the dial). With the Master level at max (10), the outs will be running at +16dBu! | |
The following readings are when the master meter is reading 0dB. On the 23/23C master level, around 7 the main balanced XLR output will run at +4dBu. True unity is around 12 o’clock or 5 on the dial. With the Master level at max (10), the outs will be running at +16dBu! | |
The following readings are when the master meter is reading 0dB. Unity on M1 & 1.4 Master 1 is around 3 o’clock (two notches below max) on the level dial. Set here the main balanced XLR output will be 0dBu. At Max, it will be running at +6dBu. Master 2 is marked with a zero to show where unity is. At Max, it will be running at +12dBu. | |
