If your GLD-80 is taking a long time to boot (i.e. several minutes), then please check your network settings section when the system has booted.
If DHCP is enabled and there is not a DHCP server connected to the system - for example, a router with DHCP enabled - boot time will be increased greatly.
If this is the case either connect a DHCP server to the system or choose static IP addresses.
