Pro X Fade uses 100% conductive plastic tracks and a wider stem for extended fader life. Pro X Fade also allows the DJ to adjust both the feel of the fader and the cut-in point to suit their personal style.
part no. description
004‐369JIT- XONE:DB4 XFADER PROXFADER A&H PART OBSOLETE!
004‐378JIT - XONE:DB2 XFADER PROXFADER A&H PART OBSOLETE!
Please note: Pro X Fade is now only available directly from http://proxfade.co.uk/shop/
Please discuss with Proxfade about compatible models and fitting.
Additional accessories can be purchased directly from the manufacturer's website:
Operating Manual Cleaning Guide Cleaning Tool Torque adjustment tool Caig Lubrication Oil [DEoxIT lube (D110L) Connector & Contact treatment]
If you need to order a spare Pro X Fader (Xone) knob, the part code is: AJ7734 (FADER KNOB PROXFADER). Speak to your approved Allen & Heath dealer or local distributor for availability and purchasing.
More information can be found on the Pro X Fade website. including details on Cleaning and Adjustment Instructions, Lag Time Adjust, Cleaning and Lubrication, Torque Adjustment and Troubleshooting.
