There are many similarities between these mixers, so the following tables show only the main differences.
ZED-10 |
ZEDi-10 |
Master level |
Rotary potentiometer |
60mm Fader |
Mono ch EQ |
3-band with adjustable mid freq |
3-band all fixed freq |
HiZ inputs |
Ch 3&4, high gain switch on rear |
Ch 1&2, line/HiZ circuit (no switch) |
Mono Jack inputs |
Interrupts XLR input |
Switchable XLR/Jack |
Stereo inputs |
ST1 includes RCA option |
Playback input |
Separate USB or playback channel |
ST3 for USB return ch 3&4 |
Main mix insert |
2 x TRS Jack insert points |
USB interface |
2 in + 2 out, 44.1 or 48kHz |
4 in + 4 out, 44.1 to 96kHz |
Record routing |
Stereo ‘Record’ bus with ch switches |
4ch with input/bus options on ch 3&4 |
Record outputs |
Stereo RCA and USB |
USB |
Chassis |
Metal w/plastic cheeks |
Metal top/back with plastic chassis |
ZED-10FX |
ZEDi-10FX |
Master level |
60mm Fader |
Mono ch EQ |
HiZ inputs |
Mono Jack inputs |
Stereo inputs |
Playback input |
Main mix insert |
USB interface |
Record routing |
Record outputs |
USB |
Chassis |
FX presets |
16 types |
61 presets |
FX to mix channel |
Separate FX return channel |
FX return uses ST2 channel |
