Introduction
Congratulations on purchasing the Allen & Heath Xone:PX5 DJ mixer.
Combining the signature warm analogue Xone sound with class leading digital connectivity, the Xone:PX5 breathes life and soul into electronic music performance. The built-in XONE:FX technology offers new levels of manipulation with our new Xone:Xcite FX suite of performance focused delays, reverbs, modulators, flangers and distorters, which are all assignable through simple hands-on control for fine tuning effects and expressing the DJ’s inner creativity.
Xone:PX5 is a 4+1 channel mixer, equipped with the legendary analogue Xone:VCF (Voltage Controlled Filter), 3 band isolator EQ on all channels, and intuitive layout.
The versatile Send/Return feature enables connection of external effects hardware with both Send/Return (Line level, or Hi-Z) and Master Insert mode connections, and equips Xone:PX5 for numerous enhanced setup scenarios. Each channel has its own dedicated send control for external effects processing and can also be routed to the internal Xone:FX engine.
Connect your laptop or computer to the premium 20, 24Bit/96kHz, Hi-Speed USB internal soundcard for easy integration into digital DJ workflows, plus connection via X:Link to Xone:K Series controllers for expanded software application MIDI control.
The cross-fader has three switchable curve settings for blending or scratching styles and can be replaced, or upgraded to the innoFADER Pro2 for ultimate cross-fader performance.
No matter what your mixing style, the Xone:PX5 combines a modern approach to DJing with all the tools required for creating your own individual sound.
Safety instructions
System operating firmware
Software licence agreement
Further information
General precautions
Register your product
Warranty
Packed Items
Check that you have received the following:
- Xone:PX5 mixer
Safety Sheet
Important! Read this sheet BEFORE starting. Retain for future reference. - Spare knobs and buttons
Mains Lead
Check that the correct mains plug is fitted.
Setup Examples
Classic
CLASSIC ANALOGUE MIX:
VINYL ONLY
CLASSIC DIGITAL MIX:
CD / MEDIA PLAYER + HARDWARE FX MEDIA PLAYER (RCA) / EXT FX (SND-RTN)
CLASSIC HYBRID MIX:
ANALOGUE + DIGITAL + MC VINYL & MEDIA PLAYER (RCA) / LAPTOP (USB) / MIC (XLR)
Advanced
ADVANCED HYBRID MIX:
ANALOGUE + DIGITAL + MIDI SYNC + CONTROL VINYL + MEDIA PLAYER (RCA) / LAPTOP (USB) /
EXT FX (INSERT + SND-RTN) / X:LINK (RJ-45)
'FULLY LOADED’ HYBRID MIX:
ANALOGUE + DIGITAL + HARDWARE FX + MIDI SYNC + CONTROL VINYL & MEDIA PLAYER (RCA) /
LAPTOP (USB) / EXT FX (INSERT + SND-RTN) MIDI SYNC (5PIN DIN) / X:LINK (RJ-45)
Rear Panel Connectors
External Effects Connectors, EXT RTN / LINE/Hi-Z / FX SEND
Balanced (TRS) 1/4” Jack. Connect external effects device outputs to EXT RTN inputs and use EXT RTN control to adjust FX signal level sent to main LR MIX or XONE:VCF.
Set input impedance for external effects between LN (suitable for Line level inputs), or Hi-Z (suitable for guitar effects pedals and legacy hardware).
Connect your external effects hardware inputs to FX SEND and outputs to EXT RTN. Use FX SEND controls to send Channel audio to the external effects device.
USB LINE / PHONO Select Switches, CH 1 - 4
Set CH1 - 4 USB SND to LN (for Line level) or PH (for RIAA level) signal input to internal soundcard. For CD / Vinyl timecode control, or to record Channel input via USB.
LINE Inputs, CH 1 - 4
Unbalanced (RCA). Connect stereo LINE level media players to the LINE input. Do not connect turntables requiring RIAA equalisation.
You can also connect to LINE level jack sources using RCA to 6.35mm (¼“) Jack adapters.
Avoid using low grade cables such as those often supplied with domestic equipment as these can quickly prove unreliable in use.
Chassis Earth Terminals
2 x Screw terminals are provided for connecting the earth straps from turntables to prevent ground hum.
PHONO Inputs, CH 1 - 4
Unbalanced (RCA). Plug in turntables with magnetic cartridges requiring RIAA equalisation. For non-RIAA turntables plug into the LINE input instead.
Do not plug in LINE level sources to the PHONO Inputs as these will overload the preamp and cause severe, high level, distortion.
X:Link
Cat-5 Ethernet (RJ-45). Connect Xone:K Series Controllers to the Xone:PX5 mixer to expand software application MIDI control and to save using USB ports on your computer.
BOOTH Outputs
Balanced (TRS) 6.35mm (¼“) Jack. LINE level stereo output feed to DJ’s local monitor.
MASTER INSERT
Unbalanced (TRS) 6.35mm (¼“) Jack. Provides INSERT points for LR MIX output to connect hardware dynamics processors such as a limiter, compressor, or graphic equaliser.
Or connect external hardware in-line with LR MIX outputs for external MASTER INSERT FX. Use Insert patch cable (Y lead), wired; Tip=Send, Ring=Return, Sleeve=Ground.
MASTER Outputs
Master1. Balanced (XLR). The main stereo LR MIX outputs that feeds the club PA system, or balanced active speakers. Wired; Pin1=Ground, Pin2=Hot(+), Pin3=Cold(-).
Master2. Unbalanced (RCA). Alternative stereo LR MIX output to feed unbalanced active speakers, or consumer type amplifiers.
MIC Input, CH A
Balanced (XLR). Use a good quality low impedance dynamic mic, wired; Pin1=Ground, Pin2=Hot (+), Pin3=Cold(-). Do not use high impedance or unbalanced microphones, or condenser mics requiring phantom power.
LINE Inputs, CH A
Balanced (TRS) 6.35mm (¼“) Jack. Connect auxiliary or balanced LINE level music sources to the CH A
LINE input. Connect mono sources to the L/M socket.
USB 9-10 Send Select Switch
Set CH9-10 USB SND to MST or FX to route LR MIX, or FX SEND output via USB.
For pre-MASTER level stereo LR MIX recording to computer, or using FX SEND for software effects plug-ins.
K-Slot
Security slot to connect locking, Kensington® type, anti-theft cable.
RECORD Outputs
Unbalanced (RCA).
Pre-MASTER level, LR MIX output for connection to external hardware recording devices.
AC Mains Input
Connect (supplied) IEC cable with moulded mains plug compatible to local AC mains supply. Turn AC supply to the mixer ON / OFF
Check the correct IEC ‘mains’ lead with moulded plug has been supplied with your mixer.
The internal power supply accepts mains voltages within the range 100-240V without changing any fuses or settings.
Ensure the IEC mains plug is pressed fully into the rear panel socket before switching ON.
ⓘ It is standard practice to turn connected power amplifiers, or active speakers, down or OFF before switching mains power to the mixer ON or OFF. This prevents any potential damage to speaker systems due to switch-on transients.
MIDI SYNC / OUT
5pin DIN.
MIDI Clock and MIDI Tx (transmit) signal output for syncing to external MIDI hardware.
USB Soundcard
USB (Type A).
20 Channel (5 Stereo IN / 5 Stereo OUT), 24Bit/96kHz, Hi-Speed USB internal soundcard. Mac OS X CoreAudio/CoreMIDI class compliant. ASIO® driver support for Windows® PC.
Input Channel A: MIC/USB/LINE
Channel FX Mode Select Switch
Selects option for Channel FX SEND routing to; INT, EXT, or DUAL. For SEND to internal XONE:FX engine, external effects hardware connected via FX SEND / EXT RTN, or to both for simultaneous use with internal and external effects.
FX SEND Control
Controls the amount of Channel audio sent to the XONE:FX bus and/or external effects hardware connected via FX SEND / EXT RTN on the rear panel.
MIC / USB / LINE Input Select Switch
Switch CH A input between XLR MIC, CH5 USB RTN soundcard input, or auxiliary CH A TRS LINE sources.
Channel GAIN Control
Adjusts the Channel input sensitivity to compensate for different audio signal source levels. -∞/+10dB.
PK! Input Signal Level LED, CH A
If the PK! LED is illuminated, turn the Channel GAIN level down.
Channel Equalizer
Each main Channel is equipped with a powerful 3 band isolator EQ, providing a controlled +6dB boost when fully clockwise and full attenuation (‘Total Kill’) on each band when fully anticlockwise.
Centre/cut-off frequencies are set at
- HF: 3.5kHz (High Frequency, treble)
- MF: 1.2KHz (Mid Frequency)
- LF: 400Hz (Low Frequency, bass)
Channel ON/OFF Switch
Turns the Channel ON or OFF, allowing audio to be routed to the main LR MIX. Useful if an un-switched microphone is used to easily bring vocals in and out of a mix. This does not affect CH A signal output to CUE.
Channel FILTER Select Switches
Press to route post-GAIN / post-EQ level Channel audio to the Xone:VCF.
Channel Cue Switch
Press to listen to the Channel pre-LR MIX audio level from PHONES and BOOTH DJ monitor outputs and to view its level on the main (MIX) Meters.
Press again to deselect CUE.
Input Channels 1-4: PHONO/USB/LINE
Selects option for Channel FX SEND routing to; INT, EXT, or DUAL. For SEND to internal Xone:FX engine, external effects hardware connected via FX SEND / EXT RTN, or to both for simultaneous use with internal and external effects.
FX SEND Control
PHONO / USB / LINE Input Select Switch
Switch CH 1 - 4 inputs between RCA PHONO,
CH 1 - 4 USB RTN soundcard inputs, or RCA LINE level audio sources.
Channel Equalizer
Centre/cut-off frequencies are set at:
- MF: 1.2kHz (Mid Frequency)
X-FADE Assign Switch
Use to assign the Channel to either X (left), or Y (right) side of the crossfader, or direct to the MIX bus when OFF (centre),
Press to route post-GAIN / post-EQ / post-Fader level Channel audio to the Xone:VCF.
The switch illuminates BLUE when active.
Channel CUE Switch
Press to listen to the Channel pre-Fader audio levels from PHONES and BOOTH DJ monitor outputs and to view its level on the main (MIX) Meters.
Press the switch again to deselect CUE.
Channel Meter
Displays the channel signal level.
Channel audio input is metered at post-GAIN / post-EQ and pre-Fader level, to display the affect of adjusting EQ on input levels before routing audio to the LR MIX.
The channel GAIN control should be set so the meter averages about 0 with loudest peaks around +6 and +9. If the ! indicator lights, turn the GAIN control down.
Channel Fader
A high quality, smooth travel, 60mm, dual-rail VCA fader adjusts the channel signal level from fully off to fully on.
XFADER
XFADER
Fade between audio from CH 1 - 4 assigned to the X (Left), or Y (Right) side of the crossfader, typically to fade smoothly into a new music track, to creatively layer sounds, or for scratch and cut mixing.
The crossfader is a VCA (voltage controlled amplifier) control that also affects the level of signals routed via the Xone:VCF
Ensure switches on channels you want to fade are set to X or Y as appropriate.
When the XONE:FX, FX X-FADE switch is set to X or Y, the cross-fader acts as a VCA, controlling send levels to the internal XONE:FX engine, following the active FX:ASSIGN (see page19) and XFADER curve switch settings.
Assigned to X, the VCA send level is X = fully ON / Y = fully OFF.
Assigned to Y, the VCA send level is X = fully OFF / Y = fully ON.
XFADE Curve Control
This switch selects the crossfader response curve between Constant power, Transition, or Fast-cut to suit scratch or cut mixing styles.
CH FADER Curve Control
This switch selects a global channel fader response curve for Stereo Input Channels 1- 4 between Constant power, Dipped, or Fast-cut to suit scratch and cut mixing styles.
Headphone Section
SPLIT Cue Switch
Selects the way the CUE bus operates.
Normally, pressing a Channel CUE switch overrides both left and right monitor program signals with the active CUE signal. With SPLIT set ON, the CUE bus overrides just the left channel, leaving the program in the right channel. L MIX meter displays CUE signal level and R MIX meter displays PRG (LR MIX level) signal.
This is very useful when beat mixing using headphones.
Cue / Mix Control
Allows the main MIX output to be blended with the CUE signal. Turned fully anticlockwise, only active CUE Channels are heard through the headphones outputs.
Gradually turning clockwise introduces the main MIX output to the headphones, together with active CUE.
Setting SPLIT, ON automatically overrides the control.
PHONES Level Control
Adjusts the level of the audio in the stereo headphones. This does not affect the level of the local booth monitor.
Headphone Outputs
Stereo 6.35mm (¼“) TRS jack and 3.5mm mini-jack sockets. Plug in good quality stereo headphones designed for DJ monitoring.
Use closed-ear headphones to provide maximum acoustic isolation when cueing your sources.
For more information, please refer to the Operating Levels section.
Master Section
MASTER Level Control
A rotary MASTER control adjusts the level of the main, MASTER 1 and MASTER 2, rear panel outputs feeding the house sound system.
This does not affect BOOTH output level or the meters.
BOOTH Level Control
Adjusts the level of the signal to the stereo BOOTH RCA output. This does not affect the headphones level. BOOTH output can be used for a DJ Booth monitor, or as an additional zone feed or recording output.
MIX / Monitor Meters
The main meters follow the selected monitor source. The default display is the, pre-MASTER, mix level which is overridden with an input channel level if the channel cue switch is selected.
In SPLIT cue mode, the left (L) MIX meter displays the cued channel signal level and the right (R) MIX meter displays Program (summed L+R mix) level. Cued MIX audio is displayed at pre-MASTER control levels, to prevent mismatch due to adjustments to the MASTER control.
NOTE: The mixer should be operated with meters averaging around 0 and loudest peaks between +6 and +9.
ⓘ If the ! indicator lights continuosly, ensure GAIN or EQ settings are not clipping Channel meters and, if necessary, turn Channel GAIN, EQ, or FADERS down to prevent the mix bus clipping.
For more information, please refer to the Operating Levels section on page 47.
EXT RTN Level Control
Adjusts the level of audio input from effects hardware connected via FX SEND / EXT RTN and routed to the Xone:VCF or LR MIX outputs.
Xone:VCF Section
EXT RTN to FILTER Select Switch
Press to route the EXT RTN input to the Xone:VCF, instead of directly into the main LR MIX, for extra versatility and creativity with your mixes.
RESONANCE Control
This produces the classic Xone:VCF filter sound by feeding some of the filter output back to its input.
The control ranges from MILD, producing a very subtle effect, to WILD, producing a dramatic phase effect with feedback just short of oscillation.
HPF Switch
Turns on the High Pass Filter (bass cut) slope. See page 46 for more details.
BPF Switch
Turns on the Band Pass Filter (bell shaped) slope.
LPF Switch
Turns on the Low Pass Filter (treble cut) slope. See page 46 for more details.
FREQ Frequency Sweep Control
This control sets the -3dB cut-off frequency for the Voltage Controlled Filter. It ranges from very low frequency (20Hz) to very high frequency (20kHz).
Xone:VCF ON / OFF Switch
Switches the Voltage Controlled Filter ON / OFF. Illuminates GREEN when active.
See the Filter Reference section for more information.
XONE:FX Control Section
FX ASSIGN Switch
Seven position rotary selector used to assign the internal Xone:FX engine routing as Channel INSERT (CH A, CH 1 - 4), Master INSERT, or SEND / RETURN to LR MIX.
Default position = SEND.
FX SEND PRE / POST Switch
Used to configure Internal and External FX SEND from Channels to pre-Fader, or post-Fader levels.
FX X-FADE Assign Switch
Assigns the XONE:FX to X (left), or Y (right) position of the cross-fader to enable fading between Wet (effected) or Dry (un-effected) signal, or OFF (centre).
Default position = OFF
FX SELECT Encoder
Scroll between XONE:FX and CONFIG options. Push ONCE to enter FX MENU, Scroll then PRESS to select FX. Push + HOLD for CONFIG options.
TFT Screen
Displays XONE:FX types or current XONE:FX settings, BPM and MIDI CLOCK details, and other MENU options dependent on the active MODE.
BEAT Adjust / Tempo BEND / MIDI Transport
BEAT - Adjust beat fraction of any time based effect (Delay, Flanger, etc).
BEND - Press to speed up or slow down BPM Clock, or to lock-in sync.
MIDI - Transport sends START, STOP & CONTINUE messages for USB and MIDI SYNC / OUT.
MODE Button Switch
3 layer functionality. Push to increment and scroll through BEAT / BEND / MIDI CLOCK modes.
TAP Tempo Button
Guide the tempo of the BPM clock manually by tapping to the beat.
XONE:FX INTERVAL Control
Rotary control to adjust beat fraction of the currently selected XONE:FX
Illuminates WHITE when active
The last adjustment setting is saved globally for FX recall
XONE:FX DECAY Control
Rotary control to adjust time based parameters for the currently selected XONE:FX.
Control illuminates RED
The last adjustment setting is saved globally for FX recall Default position = MIN (fully anti-clockwise).
XONE:FX FOCUS Control
Rotary control with centre detent used to adjust tonal parameters for the currently selected XONE:FX. Turning anti-clockwise = LPF. Turning clockwise = HPF Control illuminates RED or BLUE when active
Control illuminates GREEN in centre (OFF) position Default position = centre (OFF).
XONE:FX LEVEL Control
Adjust XONE:FX output level to LR MIX in SEND mode. Blend level between Channel audio and selected XONE:FX in INSERT mode.
Illuminates RED when SND / RTN is active.
Illuminates CYAN when INSERT is active.
XONE:FX ON Switch
Turns the internal XONE:FX channel ON / OFF.
XONE:FX CUE Switch
Press to listen to the FX channel pre-Fader signal level from PHONES outputs and to view its level on the main LR MIX meters.
Illuminates RED when active.
Xone:Xcite FX Library Reference
| NAME | FX1 PROGRAM | FX2 PROGRAM | BEAT | INTERVAL | DECAY | FOCUS |
| MASIF-Q DELAY | Stereo Beat Delay (Pre Delay Filters) | Time Fraction | Time MS | Delay Regen | Delay Output Filters | |
| PCM DELAY | Stereo Beat Delay (Pre Delay Filters) | Compressor | Time Fraction | Time MS | Delay Regen | Delay Input Filters |
| FILTER DELAY | Stereo Beat Delay (Post Delay Filters) | Compressor | Time Fraction | Time MS | Delay Regen | Delay Output Filters |
| DLY & RVB | Stereo Beat Delay | Hall Reverb |
Time Fraction |
Time MS | Delay Regen | Reverb Filters |
| MOD DELAY | Bucket Brigade Delay | Mod Doubler | Time Fraction | Time MS | Delay Regen | Mod LFO Speed |
| TAPE ECHO | Space Echo | Echo Repeat Rate | Echo Intensity | Echo Tone | ||
| CLEAN PLATE | Plate Reverb | Reverb Diffusion Level | Reverb Decay Time | Reverb Filters | ||
| SWELL VERB | EMT Reverb | Compressor | Reverb Diffusion Level |
Reverb Decay Time |
Reverb Filters | |
| CONCRT HALL | Plate Reverb | Reverb Diffusion Level | Reverb Decay Time | Reverb Filters | ||
| TILED ROOM | Room Reverb | Reverb Diffusion Level | Reverb Decay Time | Reverb Filters | ||
| ATTACK GATE | Stereo Beat Delay | Gated Reverb | Time Fraction | Time MS | Gated Reverb Attack Time | Gated Reverb Filters |
| RESO GATE | Stereo Beat Delay | Gated Resonator | Time Fraction | Time MS | Gated Resonator Release Time | Gated Resonator Frequency |
| FLANGER | Mod Flanger | Compressor | Time Fraction | Time MS | Mod Resonance | Mod Depth |
| PITCH VERB | Vocal Shifter | Plate Reverb | Reverb HF Slope | Reverb Decay time | Vocal Shifter Semitones | |
| TIME WARP | Vocal Shifter | Stereo Beat Delay | Time Fraction | Time MS |
FX2 > FX1 Feedback Level |
| DISTORTION | Clipper | Distortion Amount |
BPM Detection
The Xone:PX5 features an internal BPM engine that is used for synchronising the internal XONE:FX to the incoming audio signal.
It is also used for transmitting or receiving midi clock information through the Xone:Sync engine.
BPM Detection
By default the Xone:PX5 BPM detection is Automatic (AUTO) between 60 - 260 BPM and continuously listens to the FX source:
When in FX INSERT for channels 1, 2, 3, 4, or A, the BPM source is derived from the Assigned Channel.
When FX ASSIGN is set to: SEND or MASTER, the XONE:FX BPM is derived from the main LR MIX Clean-feed (Pre XONE:FX Return).
Hold TAP for 3 seconds to reset BPM detection back to AUTO
MIDI Clock Transmit
The Xone:PX5 can generate internal MIDI clock signals which can be sent via USB to a DAW, or via the MIDI SYNC / OUT port to external hardware.
Refer to the MIDI SETUP Menu option on page 23 for details.
When MIDI Clock Transmit is OFF BPM Detection is Automatic (AUTO) When MIDI Clock is ON FX unit BPM is derived from the Master MIDI Clock.
MIDI Clock BPM can be adjusted from the menu on the screen or by the ‘BEND’ layer on the top
panel buttons < >
Tap Tempo will overwrite Master MIDI Clock BPM BPM Clock range 60.00 – 260.00
BPM Accurate to: 000.00 - 2 decimal places
MIDI Clock Receive
If your playback source is a DAW or DJ software running through the internal Hi-Speed USB multi- channel soundcard, you can use MIDI clock as the timing source for the Xone:PX5; this will override normal BPM detection and affects all channels.
If you select this mode ensure that your DAW supports sending MIDI clocks, and that this feature is enabled.
When MIDI Clock is set to OFF BPM Detection is Automatic as above (BPM Detection). When MIDI Clock is set to Receive FX unit is derived from the incoming external MIDI Clock .
Xone:Sync
The Xone:PX5 features Xone:Sync which enables you to synchronise external equipment through the USB connection and the MIDI SYNC / OUT port.
Xone:Sync can generate internal MIDI clock signals which can be sent via USB to a DAW or via the MIDI SYNC / OUT port to external hardware devices, such as drum machines, synths or external effects processors.
It can also receive MIDI clock signals via USB from a DAW or DJ performance software which will ensure that the XONE:FX engine is synchronised accurately to the incoming audio signal.
Sending External MIDI Clock via USB
Connect the Xone:PX5 directly to your laptop using a type A-B USB cable.
Ensure that your DAW is set-up to receive MIDI clock (consult the
manufacturer’s documentation to find out how to do this).
In AUTO BPM detection mode, the Xone:PX5’s internal BPM engine will set the BPM based on the incoming audio signal of the channel selected by the FX ASSIGN control.
In this example, the AUTO BPM engine will detect the BPM from the input signal of Channel 2.
This will be used as the tempo of the MIDI clock output via USB to your DAW.
To control the playback
Press the MODE button to enter the GREEN layer.
This mode controls the MIDI Clock transport controls; STOP / START / PAUSE
To send the Xone:PX5’s internal MIDI Clock to your DAW,
press the PLAY button.
So long as your DAW is set to receive MIDI Clock correctly, this will start playback in the software.
Pressing the STOP button will stop playback.
Sending External MIDI Clock via MIDI SYNC / OUT
Connect the Xone:PX5 to your external device using a 5pin DIN MIDI cable. Ensure that your DAW is set-up to receive MIDI clock.
Consult your software application documentation to find out how to do this.
Follow the steps above to control the playback of your external device.
Adjusting the Xone:Sync DIN offset
When sending external MIDI Clock via the MIDI SYNC / OUT port, you can offset the signal in order to time-align the synchronisation of external hardware devices, which compensates for the inherent latency when syncing external devices.
| 1 |
To access the DIN offset control, hold down the FX SELECT control to enter the CONFIG menu.. Use the FX SELECT control to scroll down to highlight DIN OFFSET. Press FX SELECT to enter the DIN OFFSET setup. |
| 2 | Press the FX SELECT control. The parameter will be highlighted in RED. | |
| 3 |
Press FX SELECT, then scroll to highlight EXIT. Press again to return to the main CONFIG menu. Use the FX SELECT control to scroll down to highlight EXIT and press to leave the CONFIG menu. Continue to adjust the DIN offset until your external device is in sync with the Xone:PX5 BPM engine. |
ⓘ It is not possible to adjust the MIDI Clock offset via USB when synchronising external software. This is achieved through the software MIDI preferences. Refer to your software application documentation for details how to do this.
MIDI Clock Tempo Bend
When sending external MIDI Clock via the USB or the MIDI SYNC / OUT port, you can bend the tempo to momentarily speed up or slow down the MIDI Clock signal in order to time-align the synchronisation of external software and hardware devices.
To access the MIDI Clock Tempo Bend controls, press the MODE button to access the BLUE layer.
By holding down either the TEMPO BEND DOWN button (<) or the TEMPO BEND UP button (>), you can momentarily speed up or slow down the MIDI Clock output, much like beat matching, in order to time-align the phase of the external software or hardware.
Receiving MIDI Clock via USB from an external DAW or DJ performance software
The Xone:PX5 can be configured to receive MIDI Clock from an external DAW or DJ performance software via the USB connection. Connect the Xone:PX5 directly to your computer using a type A-B USB cable.
1 | Hold down the FX SELECT control to enter the CONFIG menu, and scroll to select CLOCK. |
2 |
Push down on the FX SELECT control to enter the CLOCK menu. Scroll and press the FX SELECT control to turn MIDI CLOCK RECEIVE ON / OFF |
3 |
Scroll down using the FX SELECT control and press FX SELECT to exit. Exit the CONFIG menu. The display will now show MIDI RX indicating that the Xone:PX5 is in EXTERNAL MIDI CLOCK RECEIVE MODE. |
ⓘ Ensure that your software is set-up to transmit MIDI Clock to the Xone:PX5. Consult your software application documentation for details on how to do this.
Now, when you start your external DAW, the Xone:PX5 BPM engine will follow the tempo set in the DAW, and the XONE:FX engine will be in sync.
USB Soundcard
The Xone:PX5 includes a 20 Channel (5 Stereo IN / 5 Stereo OUT), 24Bit/96kHz, Hi-Speed USB internal soundcard.
The interface is a Mac USB Class Compliant CoreAudio CoreMIDI device, so no hardware installation is required for operation with Mac OS X, macOS, iPad OS, or iOS USB hosts
For operation with Microsoft Windows® PC, refer to the PC Driver Installation article.
USB Soundcard Specification
| Channels: | 20 Channel (5 Stereo IN / 5 Stereo OUT) |
| Supported Variable Buffer Sizes: | 32 / 64 / 128 / 256 / 512 / 1024 / 2048 / 4096 / 8192 samples |
| Supported Sample Rates: | 44.1 kHz / 48kHz / 88.2kHz / 96kHz |
| Bit depth: | 24Bit |
| USB MIDI Ports: | 1 x MIDI IN / 1 x MIDI OUT |
| DEFAULT USB AUDIO ROUTING | ||
| Mixer Channel to Computer | ||
| Soundcard Input | Xone:PX5 | DAW Software IP Option |
| USB_1 | CH1 L (RIAA or LINE)_SND_L_1 | Analogue 1 |
| USB_2 | CH1 R (RIAA or LINE)_SND_R_1 | Analogue 2 |
| USB_3 | CH2 L (RIAA or LINE)_SND_L_2 | Analogue 3 |
| USB_4 | CH2 R (RIAA or LINE)_SND_R_2 | Analogue 4 |
| USB_5 | CH3 L (RIAA or LINE)_SND_L_3 | Analogue 5 |
| USB_6 | CH3 R (RIAA or LINE)_SND_R_3 | Analogue 6 |
| USB_7 | CH4 L (RIAA or LINE)_SND_L_4 | Analogue 7 |
| USB_8 | CH4 R (RIAA or LINE)_SND_R_4 | Analogue 8 |
| USB_9 | MASTER L or FXSEND_L_A | Analogue 9 |
| USB_10 | MASTER R or FXSEND_R_A | Analogue 10 |
| Mixer Channel from Computer | ||
| Soundcard Output | Xone:PX5 | DAW Software OP Option |
| USB_1 | CH 1 L (USB)_RTN_L_1 | Analogue 1 |
| USB_2 | CH 1 R (USB)_RTN_R_1 | Analogue 2 |
| USB_3 | CH 2 L (USB)_RTN_L_2 | Analogue 3 |
| USB_4 | CH 2 R (USB)_RTN_R_2 | Analogue 4 |
| USB_5 | CH 3 L (USB)_RTN_L_3 | Analogue 5 |
| USB_6 | CH 3 R (USB)_RTN_R_3 | Analogue 6 |
| USB_7 | CH 4 L (USB)_RTN_L_4 | Analogue 7 |
| USB_8 | CH 4 R (USB)_RTN_R_4 | Analogue 8 |
| USB_9 | CH 5 L (USB)_RTN_L_A | Analogue 9 |
| USB_10 | CH 5 R (USB)_RTN_R_A | Analogue 10 |
The Xone:PX5 internal soundcard brings support for DVS control to professional 4-deck DJ software including Traktor Pro, djay Pro, Virtual DJ Pro, Rekordbox (Core, Creative, Pro).
Connecting X:Link Controllers
The Xone:PX5 includes X:Link, enabling remote control over computer software programs via a direct connection between the mixer and Xone:K Series MIDI Controllers.
X:Linnk uses a standard RJ-45 connector to distribute power and MIDI data, avoiding the need to use additional computer USB ports, or a USB hub.
Connect a Cat-5 Ethernet (RJ-45) patch lead to the X:Link OUT socket of the controller. Connect the other end of the Ethernet cable to the X:Link socket on the rear panel of the Xone:PX5
ⓘ Ensure the Xone:K Series device is configured to send and receive MIDI messages via a different channel to the Xone:PX5
For example: Xone:PX5 = CH16 / Xone:K = CH15
It is also possible to further expand remote MIDI control over software by ‘daisy-chaining’ two Xone:K Series controllers, using another Cat-5 Ethernet (RJ-45) patch lead between X:Link OUT on the second Xone:K Series unit and X:Link IN on the controller connecting to the X:Link socket on the Xone:PX5 rear panel.
ⓘ When Xone:K Series devices are daisy-chained, ensure both controllers are configured to send and receive MIDI messages on different channels, and that they are not set to the seame MIDI channel as the Xone:PX5 mixer
For example: Xone:PX5 = CH16 / 1st Xone:K = CH15 / 2nd Xone:K = CH14
Using X:Link setups described above, the Xone:PX5 must be selected as the MIDI device for the USB host software from the application's MIDI preferences.
Please refer to your software application documentation for details on how to do this.
Xone:VCF Reference
The Xone Voltage Controlled Filter
A Voltage Controlled Filter is an audio filter where the cut-off frequency is altered by a DC control voltage rather than a variable resistor. This produces a much wider operating range and more control over the filter response to create unlimited combinations of tonal effect.
Filter Type Select
The filters are ‘state variable’. This means that they provide three simultaneous filter types: high-pass, band-pass and low-pass. Three large illuminated switches select which type is active.
You can press any combination together to create different response types such as ‘notch’ and an interesting ‘all-pass’ effect. The switches are ‘soft switched’ for live performance, meaning that the audio signal is ramped between filter states to prevent audible clicks.
NOTE: the last selected Xone:VCF response and Channel FILTER assignments are saved when mains power to the mixer is turned OFF.
The graphs below show typical effects on audio frequency response for the three filter types. The range of sweep from low to high frequency is shown together with the effect of adjusting RESONANCE (one frequency with several resonance settings shown).
The vertical scale shows the amount of cut or boost around the normal 0dB operating level. The horizontal scale shows the change in frequency from low (bass) to high (treble).
