Safety instructions
System operating firmware
Software licence agreement
Further information
General precautions
Register your product
Warranty
Welcome to Your New Mixer
CQ is the most compact fully featured digital mixer range we’ve ever created - combining the latest in audio technology with simple and intuitive app control, in a unit you can fit in a backpack.
This CQ-20B has been designed to serve you (and your audience) for many years to come. So read the safety notes, register your mixer, grab the latest firmware and user guide from our website and get started!
- XLR Inputs 1-8: XLR mic/line inputs
- Combi Inputs 9-14: XLR or jack mic/line inputs
- Combi Inputs 15-16: XLR or jack mic/line/Hi-Z inputs
- Stereo Inputs: Jack line inputs
- Wi-Fi Aerial: Built-in wireless antenna
- Alt Outputs A-B: Assignable jack outputs
- Headphone Output
- Footswitch: Single/dual footswitch
- Main Outputs: Main left/right outputs
- Outputs 1-6: Separate mix outputs
USB A: Stereo rec/play and Data to USB drive
USB B: Stereo/Multichannel Audio/MIDI interface - Chromatic Meter: RGB meter/indicator
- Network: External control/router
- SD Card: Multitrack rec/play
Firmware, User Guide and apps
To get the most out of your CQ, visit www.allen-heath.com/resources to download the latest version of firmware and matching user guide.
You can also download the free CQ-MixPad app (available for Mac/Windows/iOS/Android) to setup and control the mixer over a network.
Powering On and Shutting Down
It is important to always power the mixer on first, before powering on any connected equipment such as amplifiers or powered speakers.
When shutting down, turn off amplifiers or speakers, ensure you have stopped any recording and finished any transferring of data, then shutdown the mixer from the home screen before turning the mixer off last.
Network & App Connection
On first boot or after a factory/network reset, the network must be configured.
The Chromatic Meter/Indicator LED will flash steadily to show which connection mode is enabled, press the RESET switch to toggle between modes:
- Flashing Blue: Connect to mixer via the built-in WiFi
- Flashing Yellow: Connect to mixer via the Network port - for direct connection or when using an external WiFi router or access point.
Connect to the CQ using the free CQ MixPad app and follow the network setup procedure if required to secure your network. More detailed instructions on this process can be found in the User Guide.
Connections
- XLR: Pin1-Ground, Pin2-Hot/Positive, Pin3-Cold/Negative
- ¼” TRS Jack: Tip-Hot/Positive, Ring-Cold/Negative, Sleeve-Ground
- Headphone: Tip-Left, Ring-Right, Sleeve-Ground
- Footswitch: Mono (TS) or Dual (TRS)
- USB-A/USB-B: Conforms to USB 2.0 standard
- SD Card Slot: Up to 32GB, SDHC, UHS-I, Class 10
- Network: RJ45, Fast Ethernet
- Power: IEC C13 mains cable, 100-240V AC 50/60Hz, 45W
Support
We want you to have the best possible experience with your new CQ and although we’ve done everything we can to make it as quick and easy as possible to use, there will always be a time when you need to ask a question.
You will find everything you need through our website, including up-to-date documentation, reference guides and video content. We also have our digital community forums, a knowledgebase and a support team on hand who are always happy to help. support.allen-heath.com
