Safety instructions
System operating firmware
Software licence agreement
Further information
General precautions
Register your product
Warranty
Welcome to Your New Mixer
CQ is the most compact fully featured digital mixer range we’ve ever created - combining the latest in audio technology with simple and intuitive control, in a unit you can fit in a backpack.
This CQ-18T has been designed to serve you (and your audience) for many years to come. So read the safety notes, register your mixer, grab the latest firmware and user guide from our website and get started!
- Power: Connection and switch
- Wi-Fi Aerial: Built-in wireless antenna
- Soft Keys: Multi-function keys
- Touchscreen Rotary: Adjust on-screen values
- Headphone Output: Monitor inputs or mixes
- Screen Select: Switch between screens
- Touchscreen: Main interface
- Soft Rotaries: Multi-function rotaries
- Stereo Line Input: Dedicated stereo input
- Outputs 1-6: Separate mix outputs
- Main Outputs: Main left/right outputs
- SD Card: Multitrack rec/play
- Network: External control/router
USB A: Stereo rec/play and Data to USB drive
USB B: Stereo/Multichannel Audio/MIDI interface - Footswitch: Single/dual footswitch
- Combi Inputs 9-16: XLR or jack mic/line inputs
- XLR Inputs 1-8: XLR mic/line inputs
Firmware, User Guide and apps
To get the most out of your CQ, visit www.allen-heath.com/resources to download the latest version of firmware and matching user guide.
You can also download the free CQ-MixPad app (available for Mac/Windows/iOS/Android) to setup and control the mixer over a network.
Powering On and Shutting Down
It is important to always power the mixer on first, before powering on any connected equipment such as amplifiers or powered speakers.
When shutting down, turn off amplifiers or speakers, ensure you have stopped any recording and finished any transferring of data, then shutdown the mixer from the home screen before turning the mixer off last.
Screens
There are 5 main screens which are accessed using the screen select keys:
- CONFIG: Setup inputs, outputs and controls.
- PROCESSING: All input and output processing, including EQ’s and dynamics.
- FADER: Adjust send levels to all outputs.
- FX: Built-in multi-FX units for Reverbs, Delays and Modulators.
- HOME: Start from a template, store/recall data, record audio and view system info and preferences.
The contents and operation of functions within these screens will change with firmware updates, so download the user guide which matches the firmware version your CQ is running for more information.
Connections
- XLR: Pin1-Ground, Pin2-Hot/Positive, Pin3-Cold/Negative
- ¼” TRS Jack: Tip-Hot/Positive, Ring-Cold/Negative, Sleeve-Ground
- Headphone: Tip-Left, Ring-Right, Sleeve-Ground
- Footswitch: Mono (TS) or Dual (TRS)
- USB-A/USB-B: Conforms to USB 2.0 standard
- SD Card Slot: Up to 32GB, SDHC, UHS-I, Class 10
- Network: RJ45, Fast Ethernet
- Power: Only use supplied AM12199 100-240V AC 50/60Hz, +12V DC 5.4A (centre positive)
Support
We want you to have the best possible experience with your new CQ and although we’ve done everything we can to make it as quick and easy as possible to use, there will always be a time when you need to ask a question.
You will find everything you need through our website, including up-to-date documentation, reference guides and video content. We also have our digital community forums, a knowledgebase and a support team on hand who are always happy to help. support.allen-heath.com
