Safety instructions
System operating firmware
The function of the IP Remote Controller is determined by the firmware (operating software) that the mixing system runs. Firmware is updated regularly as new features are added and improvements made.
ⓘ Check www.allen-heath.com for the latest version of mixer or AHM firmware. AHM requires firmware V1.52 or higher to work the IP4.
Software licence agreement
Further information
Please refer to the Allen & Heath website for further information, knowledgebase and technical support. For more information on mixer or AHM processor setup and mixing functions please refer to the respective guides available for download at www.allen-heath.com.
ⓘ Check for the latest version of this Getting Started Guide.
General precautions
- This product must be installed by a professional installer or qualified engineer.
- Clean the equipment with a soft brush and dry lint-free cloth. Do not use chemicals, abrasives or solvents.
Register your product
Packed items
Check you have received the following:
- IP4 Remote Controller
- QR Code Card
- Safety Sheet
Introduction
The IP4 is part of the Allen & Heath IP Series of remote controllers. It interfaces with the AHM system via standard TCP/IP Network connections and can therefore be networked with other controllers, computers and third party devices using standard Ethernet infrastructure. It is powered over Ethernet (PoE).
The IP4 controls and functions are programmed using the AHM System Manager software and can suit a number of applications including:
- Source selection, for example for background music.
- Scene / Preset selection, for example to recall different room configurations.
- External/IP control.
- Level Up/Down.
- Mute control.
Mounting the Remote Controller
IP4 /US
This model fits standard US single-gang electrical boxes (NEMA WD-6 standard) with a minimal depth of 25mm. It accepts Leviton Decora and compatible face plates. Refer to the instructions of the face plate and/or wall box for screw specification and mounting.
IP4 /EU
This model fits standard UK wall boxes (BS 4662) and European wall boxes (DIN 49073) with a minimal depth of 30mm and Honeywell / MK Elements or compatible plates. Refer to the instructions of the face plate and/or wall box for screw specification and mounting.
Front Panel
- Illuminated Buttons – Available functions include Level Up/Down, Mute, Source Selector, External & IP Control, Scene / Preset Select, Room Control.
Connection and configuration
The IP4 provides a Fast Ethernet, PoE compliant network port for connection to the mixing system.
ⓘ The maximum cable length is 100m. Use STP (shielded twisted pair) CAT5 or higher cables.
System connection
Connect the IP4 and the AHM Network port to the same PoE network switch using a CAT5 cable up to 100m long.
At power up, the IP4 button LEDs will display any assigned function that has been set for the unit after a few seconds.
ⓘ If the firmware in a connected IP Remote Controller is not the same version as that in the mixing system, then the host mixer or processor will automatically update the IP firmware at power up.
ⓘ Either of the two PoE standards 802.3af (15.4W at source) or 802.3at (25.5W at source) is suitable. Check that the overall power rating is enough to provide for all IP Remote Controllers you wish to connect (allow 5W per IP4 unit).
Set up the unit Name and IP Address
When connecting multiple IP Remote Controllers to the same network, ensure each unit is set to a unique Name and IP Address beforehand. Alternatively, you can enable DHCP on the Remote Controllers, provided a DHCP Server is present on the network and the DHCP range is compatible with the IP Address of the mixing system.
The factory default settings are as follows:
| Unit Name | IP4 |
| DHCP | Off |
| HTTP | On |
| IP Address | 192.168.1.76 |
| Subnet Mask | 255.255.255.0 |
| Gateway | 192.168.1.254 |
There are two ways of editing these settings:
Browser access – Connect the IP4 and a PC or Mac computer to the same PoE network switch. Set your computer to a compatible, static IP Address, for example 192.168.1.100 with Subnet 255.255.255.0. Open a web browser and type the IP4 default IP Address 192.168.1.76 in the URL bar. This will give access to its network settings. Repeat the operation for each IP4 unit in the system.
ⓘ Browser access is disabled if the HTTP setting is turned off in AHM System Manager.
System software – Connect the IP4 and the AHM Network port to the same PoE network switch. Use the System Manager software to edit the IP4 network settings. Once applied, repeat the operation for each IP4 unit in the system.
ⓘ Refer to the AHM guide available for download at www.allen-heath.com for more information.
Reset Network Settings
| US | UK/EU |
Switch 5 on the main PCB board lets you reset the network settings to factory default. To reset, press the switch for 10s whilst applying power to the unit.
Programming the Remote Controller
Use the AHM System Manager software to configure the controller as appropriate.
The functions and assignments of the IP4 are stored in the AHM Presets. They are not stored locally on the Remote Controller.
