Template Shows provide a quick starting point by giving you a familiar layout and classic mix architecture. They contain default Scenes to reset the mixer settings, patch and Surface layout to the starting point.
FoH and MON Shows have:
- Strip Layout
- Avantis - Input fader strips on left banks, Mix and DCA masters on right bank.
- Avantis Solo - Inputs on layers A through C, Aux sends on layer D, FX sends/returns on layer E, Mix and DCA masters on layer F
- Custom Rotaries assigned to Compressor parameters (follow SEL)
- SoftKeys, IP Controllers, Virtual SoundCheck settings, Talkback HPF and Soft Rotary Controls are Safe in the Global Safes.
Template Show Default Patching - Inputs
| Solo | Avantis | Solo (dPack) | Avantis (dPack) | |||||
| Socket | Channel | Socket | Channel | Socket | Channel | Socket | Channel | |
| SLink I/P | 1-48 | 1-48 | 1-48 | 1-48 | 1-80 | 1-80 | 1-80 | 1-80 |
| Local Mono I/P | 1-5 | 49-53 | 1-5, 7-8 | 49-53, 55-56 | 1-5 | 81-85 | 1-5 | 81-85, 87-88 |
| Local Stereo I/P | x | x | 9/10, 11/12 | 57/58, 59/60 | x | x | 9/10, 11/12 | 88/90, 91/92 |
| Local Talkback | 6 | 54 | 6 | 54 | 6 | 86 | 6 | 86 |
| AES I/P | 13/14 | 61/62 | 13/14 | 61/62 | 13/14 | 93/94 | 13/14 | 93/94 |
| USB Playback | - | 63/64 | - | 63/64 | - | 95/96 | - | 95/96 |
Template shows include I/O patching that can be changed to suit the system connections. For information on how to change I/O patching, see the I/O section of this guide.
FOH
This Template configures a traditional architecture and layout with stereo LR main mix for mixing FoH and monitors from FoH. This is the factory default Show loaded.
Bus architecture:
- 4 Groups (2 Mono, 2 Stereo)
- 8 Mono FX Sends
- 13 Aux (8 Mono, 5 Stereo)
- 4 Matrix (2 Mono, 2 Stereo)
- LR (single fader strip)
Monitors
This Template configures the Avantis as a dedicated monitor console with 16 monitor mixes.
Bus architecture:
- 0 Groups (0 Mono, 0 Stereo)
- 8 Mono FX Sends
- 16 Aux (8 Mono, 8 Stereo)
FOH LCRplus
This Template configures a traditional architecture and layout with three way LCR+ main mix for mixing FoH and monitors from FoH, with a centre speaker or centre cluster with divergence control.
Bus architecture:
- 8 Mono FX Sends
- 12 Aux (8 Mono, 4 Stereo)
- LCR+ (Separate fader strip)
