The Bank view provides an at-a-glance overview of all channels assigned to the active fader Bank and Layer. It follows both channel selection and Layer selection, so that it always displays the channels you are working on.
The Bank view can be used with the Copy/Paste/Reset, Pre/Post, Safes, Freeze and Listen keys, for example for copying a single processing block to one or multiple channels. See 1.2 for details on using these keys.
Input Channels
Displays name and colour, source type, preamp meter, gain, +48V and polarity, gate graph, filters, PEQ graph, compressor graph, Pan and channel meter. The channel name is framed in orange when Virtual Soundcheck is active.
1. Tap on a channel Name Block to select. The selected channel is highlighted in green.
2. Tap on a Processing Block (e.g. PEQ) within a selected channel to open the associated processing page and select the channel.
DCA Channels
Displays name, colour, members (assigned channels) and the ‘Fader to Zero dB’ option. Use the Routing screen or the Assign keys to assign channels.
Mix Channels
Displays name and colour, Ext Input, meter (pre-processing), polarity, PEQ graph, compressor graph, and channel meter (post-processing).
1. Scroll the list up or down if the members are too many to fit in the strip.
2. Pull down the name of a selected Mix channel to display details of the Ext Input source such as socket number. Pull down the name again to restore the normal view. Use the I/O or Processing / Ext In screen to patch sources.
