Important Information
Safety
Before powering on the CQ, read the safety instructions sheet
(004-1511-01 or 004-1512-01) supplied with the unit. For your own safety and that of the operator, technical crew and performers, follow all instructions and heed all warnings included in these documents and those printed directly on the equipment.
Ventilation
Do not obstruct any of the air vents when in use. Adequate ventilation is especially required for the cooling fan found on the bottom of the CQ-18T and CQ-12T, and the side of the CQ-20B.
Updates to this user guide
This user guide is intended to be used and distributed in a digital format; it may be up issued at any time. Always ensure you are referring to the latest version which matches the firmware version being used, and avoid printing a hard copy wherever possible.
Registration
To be kept informed of updates, the latest firmware and new releases for the CQ range, register your CQ at https://www.allen-heath.com/resources/
Support
For further support with CQ, please visit support.allen-heath.com, or contact your local distributor.
Trademarks and Logos
SD and SDHC are trademarks of SD-3C LLC.
Firmware updates and apps
Visit www.allen-heath.com/myCQ to obtain the latest version of firmware and ensure you are registered to receive notifications on future updates.
The firmware on the CQ and all app versions must have the same major release number. This is the first two digits of each release number.
Firmware V1.1.3 and App V1.1.5 = compatible
Firmware V1.1.3 and App V1.2.3 = not compatible
Introduction
Welcome to the CQ User Guide.
CQ is a range of portable, standalone digital audio mixers which use 96kHz processing and include assistants and tools designed to be used by technical and non-technical users alike.
There are 3 models in the range, two with hands-on control, and all of which can be controlled remotely. All have a similar set of features and specifications, with differences in I/O, channel count and control options.
The different models
| Mic/Line Inputs |
5x XLR 5x ‘Combi’ XLR/TRS |
8x XLR 8x ‘Combi’ XLR/ TRS |
| Stereo Line Inputs | 1 (2x Balanced TRS) | 1 (2x Balanced TRS) | 2 (4x Balanced TRS) |
| Main Outputs | 2x XLR | 2x XLR | 2x XLR |
| Monitor/Aux Outputs |
6x Mono Balanced TRS |
6x Mono Balanced XLR |
| Headphone Outputs | 1x ¼” TRS | 2x ¼” TRS | 1x ¼” TRS |
| Touchscreen | 7” Multi-Touch | 7” Multi-Touch | - |
| SoftKeys | 3 | 3 | - |
| Soft/Smart Rotaries | - | 3 | - |
| FX Engines | 2 | 4 | 4 |
CQ-18T Hardware Overview
CQ-12T Hardware Overview
CQ-20B Hardware Overview
Images and examples in this guide
This guide uses screenshots from the CQ-18T, which includes all the features of the CQ-12T and more.
CQ-MixPad, used to control all models, has an almost identical user interface with a few layout differences (listed in the CQ-MixPad section of this guide) so is not shown in addition.
Features specific to any model or interface are noted.
