Important Information
Safety
Before powering on the Qu, read the safety instructions sheet (004-1511-01) supplied with the unit. For your own safety and that of the operator, technical crew and performers, follow all instructions and heed all warnings included in these documents and those printed directly on the equipment.
Ventilation
Do not obstruct any of the air vents when in use. Adequate ventilation is especially required for the cooling fan found on the bottom panel of the mixer which draws in air from the sides.
Updates to this user guide
This user guide is intended to be used and distributed in a digital format; it may be up issued at any time. Always ensure you are referring to the latest version which matches the firmware version being used and avoid printing a hard copy wherever possible.
Registration
To be kept informed of updates, the latest firmware and new releases for the Qu range, register your Qu at www.allen-heath.com/myQu
Support
For further support with Qu, please visit support.allen-heath.com, or contact your local distributor.
Trademarks and Logos
SD and SDHC are trademarks of SD-3C LLC.
Firmware updates and apps
Visit www.allen-heath.com/myQu to obtain the latest version of firmware and ensure you are registered to receive notifications on future updates.
For full compatibility, the firmware on the Qu and all app versions should have the same major release number. This is the first two digits of each release number. For example:
Firmware V1.2.0 and App V1.2.1 = fully compatible
Firmware V1.1.3 and App V1.2.3 = app will run in Legacy mode, some features may not be available
Introduction
Welcome to the Qu User Guide.
The Qu range of 96kHz digital audio mixers are designed to combine ease-of-use with powerful processing, making them ideal for a wide range of applications and suitable for technical and non-technical users alike.
All Qu models feature the same XCVI core, providing 32 mono and 3 stereo channels, 12 mixes, 4 matrices, 6 FX engines, plus an SLink port for connection to the Everything I/O ecosystem of remote expanders.
Different Models
There are 4 frame sizes in the range, each with a different number of channel fader strips and local input/output sockets.
Each frame size has a Dante enabled variant indicated by a ‘D’ suffix, for a total of 8 models.
Faders |
8 + 1 |
16 + 1 |
24 + 1 |
32 + 1 |
Fader Layers |
6 |
4 |
4 |
4 |
Mic/Line Combi Inputs |
16 |
16 |
24 |
32 |
| Stereo Line | 1 | 2 | 2 | 2 |
| Talkback | - | 1 | 1 | 1 |
| XLR Outputs | 8 | 12 | 16 | 20 |
| AES Outputs | 1 | 1 | 1 | 1 |
| 19” Rackmount | Rack kit available | Rack kit available | - | - |
Dante variants
The Qu-3D, Qu-5D, Qu-6D and Qu-7D all include a dedicated Dante etherCON port alongside the SLink port. This can be connected to a Dante network or to any other Dante enabled device for 16x16 channels of 48kHz or 96kHz audio.
If more channels are required, a 32x32 Dante Upgrade Add-On is available to purchase from shop.allen-heath.com which doubles the channel count of the Dante port.
Updating Firmware
There are two methods for updating Qu firmware, either with the Qu-MixPad app or by using a USB drive connected to the Qu Drive/USB-A port.
Updating firmware (from V1.1.0 onward) will not clear or delete data, but it is best practice to store a show before carrying out an update if possible.
Update firmware using the Qu-MixPad app
- Download the latest version of the app.
- Connect Qu-MixPad to the Qu (see the App Control section)
- If an update is required, the app will provide details and instructions on screen, with an option to begin the update process.
- Confirm the update on the Qu.
- Restart the Qu.
- Check that the new version has installed correctly by looking at the version shown in the bottom left of the Home screen (displayed on startup, or when no channel is selected, and PROCESSING or ROUTING screen keys have been selected).
