Current Version
V1.21 Maintenance release - June 2026
Includes DT Control Firmware V1.4
Fixes:
- DT Preamp Control could sometimes crash on large scale Dante networks.
Previous Versions
V1.20 Feature release - March 2026
Features:
- Support for DT expanders on Dante Domain Manager (DDM).
- Increased maximum number of connected DT expanders from 16 to 32.
- Added Detected Devices ‘Refresh’ button.
Fixes:
- DT Preamp Control could crash on large Dante networks with a high number of DT units.
V1.12 Maintenance release - June 2024
Fixes:
- In rare circumstances DT Preamp Control could crash on startup.
- Sometimes macOS would grey out the Interface Configuration button.
V1.11 Maintenance release - February 2022
Fixes:
- DT Preamp Control could crash when certain Dante devices were connected to the same network.
- Renaming multiple channels in Dante Controller could sometimes cause DT Preamp Control to crash.
- Rounding of gain value could result in 1dB difference in the displayed value when comparing DT Preamp Control to the mixer.
V1.10 Feature release - March 2021
Features:
- Support of latest DT168 hardware following component changes.
- Fixes an audio glitch when switching mixer Audio Sync settings.
Improvements:
- List of detected devices now ordered alphabetically.
Fixes:
- Gain values erroneously displayed decimal points.
V1.00 Initial release - January 2021
Known Issues
Failure to connect to expanders on different subnet:
DT expanders on a different IP subnet are listed as Detected Devices but DT Preamp Control will fail to connect.
Failure to connect to expanders on secondary network interface:
DT expanders on a network interface other than the selected interface may be listed as Detected Devices but DT Preamp Control will not connect.
Units take a long time to establish connection:
On larger or busier networks, it can take up to 3 minutes to establish the initial connection. Once connected however, there should be no delay in operation.
Notes
ⓘ DT Preamp Control supports a maximum of 32 DT expanders on the Dante network.
ⓘ The DT168 and DT164-W have two firmware components:
- The Dante firmware reported in Dante Controller and updated via the Audinate Firmware Update Manager.
- The Allen & Heath control firmware, which is updated via the Allen & Heath DT Preamp Control app. DT Preamp Control supersedes the original Allen & Heath DT Firmware Updater.
