Neutrik offers different grades and lengths up to 500m. We recommend opticalCON Duo X-Treme for live outdoor use, but the standard opticalCON DUO is perfectly fine for installations.
There are many other options on the market, but please follow these guidelines:
- Connectors - although our cards are compatible with standard LC connectors, we recommend using locking Neutrik opticalCON DUO connectors. Only use LC for short patch cables from the fibreACE card to a patch panel, if required.
- Cable – use a multimode, OM3 or OM4 duplex fibre cable.
In any case, we recommend sourcing a bulk assembly unless trained fibre engineers can terminate the cables on site.
For lengths over 500m, single-mode fibre is required, which the fibreACE card doesn’t support. Where this is required, we suggest patching CAT5e from the gigaACE ports to an external CAT to fibre converter (for example Fiberfox FCM-GMC or Whirlwind MCM1000).
