If you are having problems accessing the ME-U Setup Application GUI, you might have an early production model (first 20 units)
The first batch of units manufactured were given an IP address = 192.168.1.100
which is not the same as that listed in the User Guide IP address = 192.168.1.40
ME-U User Guide AP9209_1
Below are the instructions from the User Guide:
Where you see a red 40 listed in the IP address, swap this for 100 instead.
_____________________________________
8.1 Setting the network addresses
Plug a Cat5 cable from your computer Network (LAN) port to the ME-U front panel Network port.
For the computer to communicate with ME-U it must have a compatible static TCP/IP address.
Check that your computer LAN port is enabled with its DHCP turned off.
Set a static computer IP address:
IP address = 192.168.1.nnn *
Subnet Mask = 255.255.255.0
Where nnn is between 1 and 254 (not 40)
The default ME-U network address is:
If this has been changed and is not known then it may be incompatible and the computer may not connect.
If this is the case reset the ME-U network settings using the front panel recessed switch.
8.2 Starting the Setup Application
Start your computer web browser.
Enter the ME-U IP address into the browser address bar: 192.168.1.40
The computer should connect and display the Status page of the ME-U Setup Application.
8.3 Reset the ME-U network settings
If the computer fails to connect then try resetting the ME-U network settings:
Turn the ME-U off. Use a thin pointed object to press the recessed ‘Reset’ switch.
Turn power back on and keep the switch pressed for 20 seconds while the unit reboots.
This resets the ME-U network to:
Default Gateway =192.168.1.254
[ NOTE - If you reset the unit as described in section 8.3, the address will be reset to 192.168.1.100 ]
8.5 System Setup page
ME-U IP Settings – Displays the current network static TCP/IP settings.
You can change these if you wish to access the ME-U via a different network.
Default settings can be restored using the front panel recessed ‘Reset’ switch.
Default Gateway = 192.168.1.254
Please note that addresses above 254 are not supported, for example 192.255.x.x
