ⓘ Refer to www.allen-heath.com for instructions on how to update the Avantis firmware and important notes about the update.
ⓘ Downgrading from V1.31 or later to V1.30 or earlier will cause user profiles to reset.
Current Version Release Notes
V2.02 - Maintenance Release. October 2026
Improvements
ID4406 - Added support for additional Shure ULXD4Q devices
- G54 (REV 5,6,7)
- G55 (REV 5,6,7)
- G56 (REV 5,6,7)
- G57 (REV 5,6,7)
- G65 (REV 5,6,7)
- G66 (REV 5,6,7)
- H54 (REV 5,6,7)
ID4420 - Added support for the latest Avantis hardware
Fixes
ID4375 - Graphic performance can decrease, occasionally causing a freeze
ID4343 - UFX Bypass softkey doesn't work on first press
ID4367 - In rare circumstances, touchscreen restarts when USB key removed
ID4368 - Chinese characters in audio file names wouldn’t display correctly
ID4313 - UFX display does not follow channel Sel
Known Issues
ID3150 - Pinch control of PEQ bandwidth does not work reliably on macOS
ID4341, ID4277 - Shutdown or Firmware Update procedure may not engage correctly on first attempt
ID2306 - MIDI Softkeys in Director send both their ‘on press’ and ‘on release’ events on press.
ID2300 - DCA Spills do not work in Director when online
ID2357 - If running Director on a Microsoft Surface, touch and hold does not trigger right click menu on Custom Rotaries
ID2906 – On the I/O screen, some patch elements may be misaligned with the grid in Director for Mac users
ID4333 - Channel name doesn't update in UFX routing menu after scene recall
Previous Version Release Notes
V2.01 - Maintenance Release. May 2026
Fixes
ID4380 - On some units, 2 or more of the RackUltra FX slots could sometimes fail to pass audio at first boot or subsequent boots.
ID4305 - Peak Limiter 76 was missing markings on attack and release knobs.
Known Issues
ID3150 - Pinch control of PEQ bandwidth does not work reliably on macOS.
ID0893 - In certain circumstances, the touchscreens can freeze on the ampersand screen when attempting to update firmware from V1.03.
ID2300 - DCA Spills do not work in Director when online.
ID2357 - If running Director on a Microsoft Surface, touch and hold does not trigger right click menu on Custom Rotaries.
ID4341 - Shutdown procedure may not engage correctly on first attempt
V2.0 - Feature Release. April 2026
New dPack Features*
- Increased channel count to 96 input channels, 56 mixes for dPack users
- Increased number of Dyn8 instances to 24
- Added CompStortion DEEP compressor model
- Dyn8 ganging
*requires dPack
New RackUltra FX Features*
- 8 new RackUltra FX slots with dedicated stereo sends and returns.
- Pre and post FX PEQ and dynamics for each RackUltra FX slot.
- New FX models:
- Spaces Reverb Designer
- Plate Reverb Designer
- Vocal Shifter
- Vocal Tuner
- Vocal Gridder
- Dual Autokey Harmoniser
- Quad Voice Harmoniser
- MIDI Harmoniser
- Amp+Cab Distortion
- Saturator
- Rhythm Delay
*requires RackUltra FX module and dPack
Other New Features
- Channel Library updates – now including Name & Colour settings and Routing.
- FX Width control for all RackExtra and RackUltra FX
- RF Integration Support for Shure SLX-D and Quad Band ULX devices.
- Mute override for channels assigned to DCAs or mute groups.
- PEQ and Dyn8 control added to custom rotaries
Smart Rotary function adds contextual control to custom rotaries for:
- Preamp and Trim
- Gates, Duckers and Expanders
- Compressors and Limiters
- PEQ and NEQ-12
- FX Parameters
- RackUltra FX parameters
- Dyn8
- Added 'Copy All Shows' function to show manager
New MIDI options and commands including:
- Global Send and Receive Enable / Disable options
- MIDI control of Global Key
- Configurable MIDI channel for each RackUltra FX slot
- Configurable MIDI CC messages for selected FX parameters e.g. Retune, Transition, Correction, Key, Scale, Bypass
Improvements
ID4187, ID3952 - Support for new Avantis hardware
ID3278 - Added PEQ width pinch gesture to FX
ID2245 - Improved performance of meters while viewing Dyn8
ID3612 – Touchscreen dimmer level now persists after reboot
ID3410 – Stability improvements to USB playback
ID3207 – Added LED and rotary diagnostic mode
ID4221 – User FX Libraries are now sorted by type.
Fixes
ID2747 – Resolved an issue where DX hub would display incorrectly in the home screen
ID4120 – AMM metering now correctly follows user metering point selection
ID3382 – Resolved an issue where gate depth could snap to 0dB
ID3824 – Cue list view now persists after reboot
ID3283 – Resolved an issue where the wrong mix channel name could be displayed when assigning the mix to PAFL
ID2887 – Improved some text visibility on Mac version of Avantis Director
ID3734 – Resolved issue where level of input channels could creep up following a crossfade scene recall
ID3428 – Resolved an issue where unit DNA could change, removing dPack from a unit
ID3724 – Removed some messages that were being incorrectly reported as errors
ID3631 – Resolved an issue where rebooting GX/DX devices could make their scene safes appear as off
ID3517 – Resolved an issue where SMR Reverb parameters could appear to have the wrong parameter values on recall
ID3429 – Pre/Post parameter is now included when copying mix settings
ID3009 – Resolved an issue where source expander threshold couldn’t be controlled from custom rotaries
Known Issues
V1.36 - Maintenance Release. March 2026
Improvements
ID3952 Added ID detection for updated fader board hardware.
Known Issues
ID3150 Pinch control of PEQ bandwidth does not work reliably on macOS.
ID0893 In certain circumstances, the touchscreens can freeze on the ampersand screen when attempting to update firmware from V1.03.
ID2306 MIDI Softkeys in Director fire both their ‘on press’ and ‘on release’ events on press.
ID2300 DCA Spills do not work in Director when online.
ID2357 If running Director on a Microsoft Surface, touch and hold does not trigger right click menu on Custom Rotaries.
V1.35 - Maintenance Release. November 2025
Improvements
ID3443 Support of latest AR/AB expander hardware.
Known Issues
V1.34 - Maintenance Release. March 2025
Fixes
ID3417 Using a Softkey to trigger audio playback would crash the console.
Known Issues
V1.33 - Maintenance Release. February 2025
Fixes
ID3247 Touching Gate or Compressor parameters assigned to Channel Strip Rotary functions no longer affects their In/Out state.
ID3331 gigaACE cards now pass control network when “Control Network Bridge” switch is enabled.
ID3353 Resolves a number of issues relating to loss of metering.
ID3367 Fixes a Director crash during logout on MacOS.
Improvements
ID3381 Support for latest IP controller hardware.
Known Issues
ID3417 Using a Softkey to trigger audio playback will crash the console requiring a power cycle.
ID3290 Downgrading from V1.31 or later to V1.30 or earlier will cause user profiles to reset.
V1.32 - Maintenance Release. September 2024
Fixes
ID3257 Connection reliability enhanced when using GX4816 and DX-Hub devices.
ID3025 Devices connected in redundant mode to DX2, DX3 and DX4 on DX-Hub now correctly switch to link B on failure of link A.
Known Issues
ID3247 Touching Gate or Compressor parameters assigned to Channel Strip Rotary functions affects their In/Out state.
V1.31 - Maintenance Release. August 2024
Improvements
- Added support for Avantis Solo recovery.
- Improvements to User Profile security.
Fixes
ID3268 Improvements to internal audio recording.
ID3214 Audio recording now stops safely on console Shutdown
ID3284 Fixed crash related to Dyn8 External Key Source.
ID3270 Fixed crash related to Virtual Soundcheck.
ID3272 Strip Assign Scene Safe would not work correctly.
ID3281 Group to FX sends now included in Scene Crossfades.
ID3177, 3157, 3246 Improvements to Popout Scene List.
ID3133 Lock Master Strips from Softkey would not work reliably in Director when online.
ID3188 IP Controller HTTP config enable / disable button could show wrong state in Director.
ID2182 LPF/HPF settings would not show in the bank view when Off.
ID1347 Copy / Paste functions would not always work reliably for Dyn8.
Known Issues
ID3025 Devices connected in redundant mode to DX2, DX3 and DX4 on DX-Hub do not switch to link B on failure of link A.
V1.30 - Feature Release. November 2023
New Features
- Support for Avantis Solo
- Popout Scene List
- PEQ width gesture control
- FX Custom Rotary control
- Support for Custom Control Multi-Unit Configs
- Lock Master Strips Softkey
- Next / Last Scene Recall display
- DX32 optional AES Professional / Consumer mode
- AES I/O card optional AES Professional / Consumer mode
- Support for DX88
Additional New Features for dPack users
- NEQ 12-band Mix PEQ
Improvements
- Support for latest Avantis Hardware
- DCA/Mute Group assignment from Routing page
- Optionally disable browser based configuration of IP controllers
- DYN8 bypass state now shown in Bank view
- Meter response time improved
Fixes
ID3014 Resolves issue where SLink Preamp scene safes could occasionally be incorrectly unassigned whilst viewing global safes
ID3148 Fix for rare crash caused by removing USB drive whilst in Library Manager
ID3089 Global Safes can no longer be changed using the Surface “Safe” key by users without appropriate permissions
ID644 Compressor control Custom Rotary encoder colours now match 16T when selected
ID3084 Support for latest QLX-D, ULX-D and Axient Shure RF receivers
ID2900 USB Record source now reliably recalls after a show recall
ID2720 DCA Spill now respects bank assignments and will spill over the correct bank.
ID2774 Renaming a Library in Director Library Manager no longer prevents the Copy To button working as intended.
ID3027 When fader at full +10dB adjacent faders may have reported incorrect position.
ID2834 Various USB Softkey playback fixes
ID3004 Fixes occasional long boot time issue
ID2389 Flanger FX Unit output reduced by 12dB
ID3180 Bootloader Network Settings config now consistently applies settings as entered by the user
Known Issues
ID3150 EQ Pinch-to-Q does not work reliably on MacOS
ID3133 Lock Master Strips from Softkey does not work reliably in Director when online.
ID3188 IP Controller HTTP config enable / disable button may not show current state in Director.
ID1347 Copy / Paste functions do not always reliably work for DYN8
ID0893 In certain circumstances, the touchscreens can freeze on the ampersand screen when attempting to update firmware from v1.03.
ID2182 LPF/HPF GUI not showing in bank view when off.
ID2357 If running Director on a Microsoft Surface, touch and hold does not trigger right click menu on custom rotaries.
V1.25 - Maintenance Release. April 2023
Fixes
ID3001 Avantis could in certain circumstances fail to boot past ampersand splash screen.
ID3003 Dante V3 I/O card no longer erroneously setting card fan speed to 0%.
ID2999 Fixes bug causing Avantis to incorrectly indicate it has not been shut down correctly on the previous boot.
Known Issues
V1.24 - Maintenance Release. February 2023
Fixes
ID2907 The Record Send function in Virtual Soundcheck now correctly functions for output 97 and above.
ID2593 FX Send Level now correctly updating in Relative Scene Update mode.
ID2972 Ducker now showing correct gain reduction value when key audio is silent.
ID2836 Inhibits incorrect display of ‘Unsafe Shutdown’ message.
Improvements
ID2977 Support for V3 M-DL-DANTE128 and M-DL-DANTE64 cards following component changes.
ID2209 Various GUI response time improvements.
Known Issues
V1.23 - Maintenance Release. January 2023
Fixes
ID2949 DX-Hub no longer gets stuck in firmware update mode.
ⓘ A DX-Hub connected to an Avantis console running V1.23 for the first time may require restarting after 5mins if still in firmware update mode.
Known Issues
ID2907 The Record Send function in Virtual Soundcheck does not correctly function for output 97 and above.
V1.22 - Maintenance Release. December 2022
Fixes
ID2916 A very specific combination of fader level and pan settings on a stereo Mix could result in noise on the Mix output.
Improvements
ID2908 Support of latest Avantis DX168 hardware following component changes.
Known Issues
V1.21 - Maintenance Release. August 2022
Fixes
ID2793 Fixes issue with metering engine that can in rare circumstances cause a console freeze.
ID2848 Resolves routing page display issue now allowing access to all controls.
ID2849 Expander metering data now shown correctly when viewing an expander on both screens of the Avantis.
ID2867 / ID2868 Fixes issue where console may freeze on audio playback from onboard play/record system.
Improvements
ID2672 / ID2689 Support of latest Avantis hardware following component changes.
Known Issues
Several other minor fixes and improvements.
V1.20 - Feature Release. June 2022
New Features
- Next Generation Real Time Analyser.
- Sennheiser Wireless Microphone Integration.
Director CSV channel setting import/export.
- Bus compressor.
- Source Expander.
- Dual Threshold Expander.
- Opttronik ‘B’ model.
- Opttronik Emphasis Control.
Updated Opto model.
Improvements
- DCA Spill Options.
- DCA on Surface.
- Right to Left Spill.
- Frozen Strip overspill.
- Softkey functions.
- Direct Out DCA follow option.
- Routing Screen dB value display.
- Support for new Shure hardware revisions (Axient, ULX-D, QLX-D)
Added global safe user permission.
Fixes
ID2658 Custom rotaries now correctly show Manual Peak compressor values.
ID2647 PEQ no longer locks PEQ touch events to PEQ band 1.
ID2664 ME patches to GX4816 connected via gigaACE now behave correctly.
ID2697 Show recall now reliably recalls Aux source points.
ID2750 Fixes boot-hang caused by malformed audio files on USB.
ID2631 Avantis Director now gracefully handles firmware mismatches.
ID2638 RF Device GUI now able to handle greater numbers of RF devices correctly.
ID2536 Firmware updates to devices cascaded from GX4816 now much more reliable.
ID2550 Meters page now shows channels 1-32 and 33 – 64 correctly.
ID2558 Erroneous start-up scene recall warning removed.
ID2577 DX164 / DX012 Cascade / Redundant mode displayed in GUI.
ID2578 Scene Recall confirmation now shown in front of Insert / FX pages.
ID2589 Show list GUI issue whereby deleting a show from the list could cause the show manager to become unusable.
ID2622 Comp and Gate gain reduction GUI accuracy improved.
ID2506 Dante / Waves SRC anti-aliasing filter for 48khz operation improved.
ID2383 Fine value control in Director now works correctly.
ID2352 Director will now show channel gain rotaries for devices connected via I/O port or SLink reliably.
ID1899 Fixes memory leak caused by channel metering.
ID1911 Level Up / Down softkeys no longer get stuck to +10 when adjusting Min / Max values.
ID1627 GX link indication now shows single Link status.
ID2318 GX4816 connected to gigaACE card during show recall would cause erroneous errors in log.
ID1538 dB value no longer erroneously shown in naming area on repatch.
ID1487 Various USB keyboard reliability fixes.
ID2472 Clock drift fix.
ID2643 FX Engine PAFL listen no longer becomes locked when changing between certain FX engine types.
ID1064 Various improvements to GUI response time
ID928 GUI no longer shows invalid paste destinations when pressing and holding the paste button.
Known Issues:
V1.13 - Maintenance Release. February 2022
New Features:
Shure Wireless Microphone Integration. (ULX-D, QLX-D, Axient Digital).
Fixes:
ID2624 Dyn8 Library pop up now appears when the Options button is touched.
ID2619 Fixes sidechain notch filter GUI touch and drag issue.
Known Issues:
ID0893 In certain circumstances, the touchscreens can freeze on the ampersand screen when attempting to update firmware.
ID2318 GX4816 connected to gigaACE card during show recall can cause erroneous errors in log.
ID1913 Talkback key in Director does not work correctly in non-latching mode.
ID2303 Solo In Place softkeys in Director do not enable SIP.
V1.12 - Maintenance Release. February 2022
Fixes:
ID2544 Scenes can now be added to the end of cue lists when cue list is over 16 scenes.
ID2579 Resolves issue whereby the connection or disconnection of Custom Control could cause the app to temporarily freeze.
ID2574 Firmware update time and performance significantly improved when updating a DX-Hub and/or cascaded DX units.
ID2045 Director now correctly displays dB level in Naming Area on level change.
ID2218 Fixes issue where Sync Selected layer in Strip Assign may not work reliably in both directions.
Improvements:
ID2489 Repositioned the Main Bus in the routing page for easier access.
ID2409 Added dPack specific splash screen.
ID2568 Updated fan controller to reduce unwanted modulation.
ID2564 Support of latest DX32 hardware following component changes.
ID2559 Support of latest DX012 hardware following component changes.
ID2556 Support of latest DX164W hardware following component changes.
ID2549 Support of latest AR & AB hardware following component changes.
Known Issues:
V1.11 - Maintenance Release. June 2021
Fixes:
ID893 In certain circumstances, the touchscreens could freeze on the ampersand screen when attempting to update firmware.
ID2434/2435/2412/2461 Several issues related to Dyn8 including erroneous ‘Insert Bypassed’ message, stereo mix channels losing Dyn8 assignment after reboot, and Listen function not working for Dyn8 bands.
ID2364/2406/2458 In some circumstances the screen application would crash and restart when attempting to shut down.
ID2334/992/1913 Several SoftKey issues including some assignments erroneously show as invalid, Tap Tempo not flashing accurately at every beat, and Talkback not working correctly in momentary (non-latching) mode.
ID2429 The global Direct Out source would switch to Post Preamp after viewing the Routing screen.
ID1647 Event Logs could cause the mixer to run out of memory after a prolonged period of use.
ID2471 Locking the mixer would not lock all screens.
ID1542 A stalled fan would only be reported if already stalled at boot up.
ID2442 Delays for mix channels were not displayed correctly after a bus config change.
ID2348 The static IP address was not greyed out when activating DHCP.
ID2438 Follow Main Pan icons were incorrectly displayed for mono mixes.
ID2414 Recalling a Show from the Director Show manager would sometimes fail.
ID2074 Block strip assignment would sometimes not work correctly.
ID2416 MIDI strips in Director would only send the default MIDI messages.
ID2307 Some MIDI MMC controls would not work reliably at every press.
ID2308 Overwriting a Template Show on a USB drive would cause errors.
ID2303 Solo In Place softkeys in Director would not enable SIP.
Known Issues
ID2424 AES and Wordclock settings are not persistent after reboot and don’t update correctly after a Show recall.
ID2510 Recalling a V1.0x Show from the Director Show file manager can fail while running Director online.
ID2306 MIDI Softkeys in Director send both their ‘on press’ and ‘on release’ events on press.
V1.10 - Feature Release. March 2021
New Features
- Support of Avantis Director (offline editor / online control software for Windows and Mac).
- Follow / Invert pan option for Stereo Auxes and Matrices.
- LCR+ Main bus mode with Divergence control.
- Support of MIDI over TCP/IP.
- Solo in Place.
- Several new routing and patching options:
- Mixes and PAFL available as Input sources
- Mixes can be patched to PAFL Ext In
- Mixes and PAFL can be patched to Mix Ext In
- Optronik compressor.
- Hypabass subharmonic synth RackFX unit.
- Transient Controller RackFX unit.
Improvements
- Embedded Scene Recall now supports remote Avantis, dLive and AHM units.
- New Softkey functions.
- New De-Esser modes.
- USB Audio Playback shows Elapsed and Remaining time.
- Stereo Record options expanded to include Tie Lines, PAFL or FX Unit outputs.
- Improved meter performance.
Fixes
ID1684 Unplugging cascaded DX unit connected to GX4816 could cause Preamp controls to disappear.
ID1635 Fixes issue whereby in certain circumstances, recalling a Scene from a Cue List would not work.
ID1630 Corrects GX4816 gain Insert behaviour. Return socket now correctly defaults to 0dB.
ID1624 Directly patching RackFX output after change from Insert to Mix could cause a crash.
ID1372 Various improvements to GUI responsiveness.
ID1354 Cascaded devices connected to AR2412 now reconnect correctly after disconnecting and reconnecting dSnake.
ID1238 Connecting SLink to gigaACE card immediately after a GX4816 could cause channels not to pass audio until Avantis is power cycled.
ID623 Side chain sources now shown correctly in drop down menu.
ID1926 Removes erroneous source point drop down for FX return.
ID1683 Corrects Preamp GUI behaviour after hotplugging GX4816.
ID1673 A Scene created with a DX unit connected now recalls correctly without the DX unit connected.
ID1667 De-Esser Dual Mono mode would always key from channel 1.
ID1563 Incorrect show was highlighted after show update.
ID1256 Matrix DCA membership indication could be incorrect in naming area after assignment.
ID1220 FX Return PEQ could recall during scene changes even when safe.
ID555 Utility page could be shown after show recall.
ID1977 FX Send name and colour could recall during scene changes even when safe.
ID1363 Scene update softkey now correctly opens scene update page.
ID1038 Adding large amounts of DCA gain (20db+) to outputs could cause audio level reduction.
ID507 Frozen strip indication could become unsynced from GUI after mix config change.
ID450 Blank space option missing from user meters.
ID1691 / ID1614 / ID1394 / ID1426 / ID1488 / ID1004 / ID935
Various USB Play/Record system fixes.
ID1188 / ID1015 / ID910 / ID1349
Various fixes to GUI behaviour on scene auto-increment.
Known Issues
V1.03 - Maintenance Release. April 2020
Fixes:
ID1619 DX expanders would not automatically update over SLink.
ID1610 Improved management of internal fan speed.
ID1607/1605 Fixes to USB playback system.
ID1624 Repatching FX units in the I/O screen could sometimes crash the software.
ID1630 Inserts over SLink would sometimes present the wrong return level.
ID1631/1629 Fixes to gain control on channel rotaries.
ID200/1553 Resolution of several Internal Errors in the Event Log.
Known issues:
ID1635 In certain circumstances, recalling a Scene from a Cue List doesn’t work.
ID1031 A disconnected IP Controller can cause controls and metering to freeze every few seconds until the IP Controller is removed from the connection list.
ID1131 Creating a stereo input can take longer if multiple pages have been viewed.
ID1354 If an AB168/AR84 is connected to an AR2412 and becomes disconnected, the AR2412 will need to be reconnected to re-establish the AB168/AR84 connection.
ID1394 When moving a recording from internal storage to USB storage, the mixer can freeze for around 60 seconds.
V1.02 - Maintenance Release. February 2020
Improvements:
- Second PAFL bus added.
- The Processing and Routing menu options now latch.
- Mono main meter added.
- Hardware Insert icons added to Bank view.
Fixes:
ID0207 AMM meters not working in Name Blocks.
ID0694 Input levels could be overwritten with Input to Matrix Send levels after a mix config change where Main is changed to None.
ID0989 The metering source point selection only affected meters on the Meters page, and not the channel strip meters.
ID1070 Pressing a SoftKey assigned to DCA Mix twice would not return the active Mix to Main.
ID1186 When sending Mains to a Stereo Matrix, the Mains send pan control would affect the Mains balance and not the send pan.
ID1420 Some Direct Out options were missing on the Routing screen when the Options button is pressed.
ID1449 The Output Patchbay option in the Scene Safe system does not safe USB audio patching.
ID1490 Under certain circumstances the mixer could crash after a scene recall.
ID1493/1509/1528 The touchscreens could freeze or crash after a show recall.
ID1500 Touchscreens could freeze after a Mix Config change.
ID1550/1565/1586/1592 Fixes to channel strip rotary behaviour in sends mode.
ID1581 Touchscreens could restart after changes to the Input Stereos configuration.
V1.01 - Maintenance Release. January 2020
Fixes:
ID1433 Occasionally the touchscreen can freeze when recalling a show with a different mix configuration to the current show.
ID1440 Internal error incorrectly shown when Name Block is configured to show IO and a strip where no IO may be assigned is selected.
ID1419 Internal error incorrectly shown when selecting mono channel after selecting stereo channel or vice versa.
V1.00 December 2019
This is the first public release of Avantis firmware.
