The DT22-M is a PoE enabled Dante I/O unit. It can be used to complement Allen & Heath digital mixing systems, or any other system on a Dante network. It provides 2 mic/line preamps with local gain and phantom power control, and 2 line level outputs. It connects to the Dante network over a single Cat cable.
The DT22-M comes complete with brackets for surface mounting.
Software
Visit the Audinate website to learn more about Dante, and download Dante Controller to route audio and configure devices on a Dante network: https://www.audinate.com/
Surface mounting
The surface mounting ears allow the device to be mounted on top or under a surface, desktop or podium, or vertically on a wall or partition. They can be installed to face either the top or bottom of the unit.
Position the ears centrally on each side of the unit, aligned with the threaded holes on the insert bars, facing either up or down as required, and secure them using the 4x M3x6mm screws provided in the package.
Rack mounting
Up to two units can be rack-mounted in a single 1U rack space with the optional rack kit DT-RK19.
| Dimensions and Weight | Width x Depth x Height x Weight |
| DT22 | 130 x 100 x 43 mm, 0.5kg (5.1” x 3.9” x 1.7”, 1lbs) |
Front panel
- Inputs Balanced Phoenix mic/line inputs.
- Output Balanced Phoenix line outputs.
- Gain Rotary controls for the preamp analogue gain, 0dB to 55dB. Use a Philips screwdriver to adjust the gain.
- PP +48V Phantom Power and Mic/Line switches for Input 1 and 2.
Rear panel
- Dante EtherCon port for connection to the Dante network and Link / Activity LED indicator. Use a PoE Ethernet switch or PoE injector to power the unit via this port.
- Power LED indicator and Ready indicator. Ready lights up when the unit is successfully booted and ready to pass audio.
- Factory Reset Hold down the recessed switch while powering up. After at least 10 seconds, remove power then power up again normally to reset the network settings and name. This will delete any static IP address and revert to factory default (DHCP / zero-conf).
- DC input DC 12V connector.
