Q: How do you turn on phantom power?
A: Phantom Power is enabled on a per-channel basis, via the corresponding channel PROCESSING screen, as follows;
- Press the 'PROCESSING' button to the right of the touchscreen to open the Channel & Processing Mix view on screen.
- Press the green 'SEL' button on the channel strip of the required input.
- Touch the 'PREAMP' tab at the top of the PROCESSING screen.
- Touch & HOLD the '48V(HOLD)' tab to enable Phantom Power on the selected channel.
- Repeat above on each channel, as required.
